Cisco 7925 Wireless IP Phone and Aruba Access Point
Hello EveryOne,Is it possible to use Aruba Access Point with Cisco Wireless 7925 IP phone? If so can any one provide me techinical Documnet.
Hi,I m trying to convert my Cisco ip phone 7945 as emergency phone in case my cisco servers break again. Is it possible to use 7945 phone without CUCM and voice gateway at all and just attach it to seperate pstn network r? probably not?
Hi all,I have one Cisco CUCM cluster for Mainsite and a branch site. So, I want to restrict privilege for administrators in branch. The administrator in branch just only have the privilege to access to IP phones which are in the branch site.Any idea...
Hi All Networkers,This is Niran. I've installed Cisco Unity Connection 8.0 on VMwareworkstation (72 gb & 2gb ram, Bridged). I'm getting high packet loss while pinging the CUC and takes long time to load the web session.Here is the ping response : Re...
Although 6.1.4 on UCS is not supported . I have installed the 6.1.4 and i am planning to upgrade to 8.6.2 on UCS . But i am getting an errorI have checked all the prerequiste for 8.6.2 on UCS and have made it according to the ova template . Even thou...
Hi All,could you please tell me what are the options to connect Remote phones (1 per site) to the Central UC560? I am at the design stepWhat do I need for the remote sites?REGARDSGCA
First off, please forgive me as I'm very new to Cisco products, and came into some information that might lead me to believe the VG200 product will do what I need.I have a private microwave IP-based network and the need to transport bi-directional au...
hi everybodyLet say we have a host Pc want to sends a packet. The host check the destination ip and see if it is on local subnet if it is on the local subnet, host simply forwards it, if it is not on the local subnet, host simply forwards it to its ...
I have a few questions about setting up a CUBE to connect a Call Manager enviornment to a SIP Trunk ITSP.We are going to use a Cisco 2821 router. I have purchased the "Grow as you go" license packs in a 100 and a 25 user quantity.1) I've installed P...
I'm trying to find someone with experience configuring Call Manager to use a Sprint SIP trunk. I need to confirm a few things.1) Do we have to connect to their SIP trunks over their MPLS network? a) If not, what are the pro's and con's to using...
I have one user that just cannot login to CAD. We get the error message: "The ID you entered was not found"In the log, we see: "ERROR DAGT3010 Error: get agent returned: <Could not find specified entry.>,."The only information I find on this error...
I have some 7945's that register to CUCM 8.5.x.The reg fine and pc behind commicates without issue. Strange thing is after a certain amount of time, the PC seems to lose connectivity after a few hours or few days.The PC was and is fine without the 79...
Is it possible to sync both ipphone and telephonenumber AD fields to DC directory? Customer wants to display both e164 and extension number in phone directory. Do not want to create dummy AD user per real one .Sent from Cisco Technical Support iPhon...
Hello All,I am getting ready to do another UCS server and was looking over my notes. Is there a separate cisco VMware template for the Unity Connection voicemail system or do we use the call manager one?trying to find all the ones i need. there was...
Subject | Author | Posted |
02-01-2023 09:39 PM | ||
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM | ||
01-16-2023 05:26 PM |
User | Count |
10 | |
5 | |
4 | |
3 | |
2 |
