IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5634 Views
  • 14 replies
Hello,I recently upgraded the software on a VG248 to 1.3(2)ES2 and now calls on a analog push button elevator phone wont work. It calls fine but when other end user hangs up does not disconnect and you hear a fast busy. It disconnects with previous s...
                   Can anyone help in providing the information?How long the phone will register in SRST mode afetr the WAN outage. will take the scenerio as the phone is in SRST mode and the WAN is  not come up.Example: If u take avaya the phone wil...
Hi out there.I got a problem with KPML.I got an CME where KPML just works fine and an CUCM 7.1.x where it doesn't.The only difference i found was in the cnf.xml for example:An working CME phone config contains <kpml>1</kpml>where an CUCM phone config...
