Hi AllI am looking for information on the release of EX90 Firmware1. EX90 TE6 release date?2. Will TE6 be free to download (out of Support contract for EX90's)?Getting mixed messages from current sources.ThanksJohn Mc
Hi guys,I'm tryng to enable Mobile Voice Access folowing this guide: http://bhatkoti.com/2010/01/02/how-to-configure-mobile-voice-access-mva-in-cisco-cucm-6-x7x/. When the MVA number is dialed (3001) the call is conected but the prompt asking the the...
Dear Friends,What is the difference between DSP for voice calls & services ?When I buy a VWIC card does it have DSP's on it, how do I configure it for voice calls and services ?Does the command voice-card refer to the DSP's on the VWIC card ?how do I...
Hi,Is it normal for calls to use channel 23 as a B channel? I've never seen this before.. Bearer Capability i = 0x8090A2 Standard = CCITT Transfer Capability = Speech Transfer Mode = Circuit ...
HiIs it possible to connect a cisco gateway to the PSTN using a E1/T1 interface and connect to the callmanager using SIPAll I can see config for is H.323 and MGCPThanksian
Hello everyone,I am looking for confirmation. If I have UC 8.x with CUCM 8.x with 3 nodes and have 48 VM ports registered to the CUCM Publisher with all 3 CUCM servers on the same port group if the CUCM Pub goes down will the VM ports automatically...
I'm in need a bit of clarification please. We have several branch locations with MGCP gateways, with MoH files loaded on them. These are custom files for each location and play when calls come in to these Gateways from the outside. Question one is if...
HiWe have a door that is opened using an analoge phone line (if you hit # on the other end it should open). The lock is connected to an ATA186.When the call is routed out of our CallManager and to the PSTN pressing the # in the other end works perfec...
I am testing an ATA and an analogue line and have noticed that certain BT phones do work and others don't.So the BT Duet 60 wll work on the ATA but not the analogue lineBut the BT Decor 2100 and BT Decor 1100 will not work on the ATA (no dial tone) b...
Good Morning All,First of all appologies if this is in the wrong category, but I couldn't find a QoS categoryI am studying QoS for my SWITCH exam and I am having a hardtime understanding the bits used for L3 IP Precedence and DSCP markingsThe texts k...
Hi All, i have a situation where customer has a phone system that we are migrating to CUCM 8.6 and today they can just dial number numbers internal and external while the phone is in ON hook state and call gets connected without having to press DI...
Hello friends,I have the following scenario:MXONE (Ericsson)<=> CUBE <=> AsteriskThe configuration of CUBE is:voice service voip allow-connections h323 to h323 allow-connections h323 to sip allow-connections sip to h323 allow-connections sip to sip h...
Hi,I have an 3945 router with analog cards(EVM-HD-8FXS/DID,EM3-HDA-8FXS/DID), which supports 24 ports.I have few of these routers with the abobe cards. So I am wondering whether the ports can be configured via BAT?I don't find any documents for doin...
cme 8.5 if ntp changed will it make license expire ? culd any one recommendThe following license(s) are transitioning, expiring or have expired.Features with expired licenses may not work after Reload.Feature: cme-srst ,Status: ...
We have Unified Callmanager 8.0 installed, with IBM Informix Dynamic Server Version 11.50.UC5XA database in the backend. There are 2 options I have found so far to query the database using SQL: AXL executeSQLQuery (Administrative XML API) and CLI (Co...
| Subject | Author | Posted |
| 03-25-2025 06:06 AM | ||
| 03-21-2025 01:42 PM | ||
| 03-20-2025 05:12 AM | ||
| 03-19-2025 06:53 AM | ||
| 03-18-2025 05:41 AM |
| User | Count |
| 5 | |
| 2 | |
| 2 | |
| 1 | |
| 1 |
