IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 1174 Views
  • 6 replies
Hi all,When trusting DSCP marking where should i put "mls qos trust dscp"? On all edge port, including uplinks? Should i also configure this on the core switch? And lastly how can i check that coming from the LAN to the router the DSCP marking was no...
Hi guys,I have configured my vmware machines running two clusters (single node) after watching this wonderful video:https://supportforums.cisco.com/videos/1970I am running two different version of CCM.Home cluster: 8.5.1Visiting cluster: 8.6.2The mom...
tacl75 by Beginner
  • 4883 Views
  • 16 replies
On one of my PRI's we have a few numbers assigned to dial in.  One of the assigned numbers is giving us the error "Your call cannot be completed as dialed, please check the number and try again - Zero Zero Four T".  All of the other numbers are worki...
I have trying with much difficulty to gather information about CUCM 9.  If anyone can answer these questions, I would be greatly appreciative.One Touch Call Recording - I know this is a new feature and requires a MediaSense server.  Does anyone know ...
Hello, Setting up a db for cdr data and have a few issues: 1. Is there a way to remove the header and datatype info from the ftp files? I just want the cdr data. 2. Is there a way to customize the file name of the file that is output?3. Is there a wa...
dmthames1 by Beginner
  • 406 Views
  • 2 replies
