Resolved! Steps to migrate from cucm 6.x to 7.x
What are the steps to migrate from cucm 6.x to 7.x?
Hello,We have some Cisco IP 7940 phones configured for a network.And we would like to make a hard reset in order to use them in another network.Please could you help us to do soWe tested the 2 methods below without success.Thanks in advanceWe tried t...
We are Currently Using Cisco Unified Communication Manager (CUCM) Version 6.x. and we are moving to Window 7 , I want to know Cisco Unified Communications Manager Attendant Console will work on Window 7 or not ?Note : As I tested A...
Hi There,I have 2901 ISR G2, whihc I have pulled out of our store room, most likely it is not supported.I am looking at getting this 2901 up as a CME 8.6. After refering to the CME & IOS Compatibility Matrix, I know that I must have 8.6 CME and also ...
Hi I have 2921 router working h.323 gateway (please attach the files) , and i have 2 manager with 2 specific FXO analog ines , my Question is :i have analog line number 2362981 , once i called from cisco phone (extension61761) to outside through FXO...
Hi allMy ip phone cisco 7971 struck in upgrading while i doing a factory reset.I had a dhcp server and option 150 command to push tftp information in my network.my router flash contain the firmware files for 7971.i don't know how to get back my [hone...
Hi,I Have a CME 9.0 with phones 3905 and IP Communicator in mode shared line, when the IP Communicator is no registered, the 3905 forward call to voicemail but this call is loop to peer of IP communicator and no answer the voicemail. ephone-dn 9 ...
Hello to ALLactually i have a issue on my CUCM Deploymenti have two diffrent Company which have only one H323 Gateway with 8 fxo ports, my problem is hwo can i seperate this two company formincoming and outgoing company, i know if i use CUCME can use...
Hi All,I need to configure Pin Code dialing for a customer. I have followed the suggestions from other forum users with the After-Hours Blocking process.Below is the configuration I have implemented to test with : -----------------------------------...
Hi all, I have a few CICPs wunning on windows xp machines in the lab. I have created a CUCM group, and I have placed in the group 2 CUCMs, 1 pub and 1 sub. The sub was meant to be first on the list and the pub second, but when that was done, the CIPC...
i'm trying to get 3 7961's to failover to the router that is controlling them and here is our setup in a nutshellcore switch (4507 redunant supervisors) server cab switch pri call manager (6.10 i think) fiber drops from core to switch a fiber drop...
I am trying to figure how to call forward a phone that then forwards to voice mail. Right now all calls keep the first number and then play the first phones voice mail. How do i get forwarding to play the second phones voice mail?
Running CUCM 6.1.4Hopefully simple question. We have a customer who wants a DN to ring to an external number simultaneously when dialed. Any suggestions on how this can be accomplished?Many thanx
I'm planning an upgrade of a CUCM 8.6.2(2a) to the 8.6.2(2 SU2) and I have some doubt about the roll-back procedure since the cluster is in Mixed Mode.Since we had a lot of problem with the installation of the first sub and now we adding anoter sub t...
HiWhen I don't use VSA all information gets logged nice and readable on the Radius server.However, I'm missing some fields and understand that vsa accounting will give me some of them. Unfortunately when I add the command below to achieve it everythi...
| Subject | Author | Posted |
| 12-31-2025 01:52 PM | ||
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM |
