Hello, I would like to ask as to when are we going to use CCM or CCME to pair it with a particular IP Phone. For example the for the 7900 Series.What the client says that the existing VOIP Server is Cisco CallManager V5.0(2). Shall I use CCM or C...
Hi All,I would like to collect traces from particular phones, could you please let me know how...
Hello All, I have a three site campus that consists of one PRI for incoming and outgoing calls demarced at our main site. Two campuses share this PRI over fiber back to our CUCM 8.6 call server at the PRI site. These same two campuses have each a Cis...
Hi to all,I have one ATA registered in the CUCM, the audio is good but I have som problems with the analogue phone. I can do all necesary functions (Off-hook, on-hook, transfer, hold, etc...) but sometimes the phone stops working properly .... And I ...
Hi Voice Gurus, This is more a design question for the VOIP savvy. We have a new branch office with about a dozen users being deployed in a few months. We are thinking of going the CME route on a 2900 router with L2L VPN capability. Our cooperate off...
Looking for a possible solution for a HCL incompatibility we have.Our DL380pG8 have XEON E5-2680 CPUs @ 2.7GHz, the http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Supported_Applications specifies the CPU type is not supported for...
I am experiencing an issue with our attendant console server, when a phone is logged out and they try to dial 0 for operator it can not be picked up through attendant console. Also calls can not be transferred to Logged out extensions, but they can b...
Good day, now I have two 6500 switches as CORE, interconnected with PortChannel, I connect a VG224 which has 2 FastEthernet ports and an interface Loopback0, copper ports every 6500, I would like to have redundancy in L3 through OSPF, but unsubscribe...
Hi All, I am having issues to convert my current voice system to pure VOIP. There is the deal, currently we have a T1 link coming from our Telco to the current PBX(TELECO ----> PBX). This works fine. Now, want to replace the legacy PBX with ...
Anyone have the same problem with redirects or ring no answer? From SCCP to SIP phones internal, ring no answer I get the default Unity Connectio greeting. If it hit the vm button on the SIP end point, I get prompted to login. Which tells me, Dir...
My customer bought the following server UCS-C200M2-VCD2 and now since this EOS can some one recommend equivalent server?ThanksAnuj
Hi , we are facing an issue that phones are not registering to CUCM sub ,Subscriber is newly installed and the replication is good.however CIPC , CUP and VG are able to register with Sub . Any help willl be higly appreciated.SH...
What is the recommendation"best practice" if I need to implement QOS for CICP users, my users will connect from INTERNET "Cisco - VPN" then they will run their Cisco IP communicator to make their business calls…what is the best practice If I need to ...
Does anyone know a part number for a power supply for an Edge 75? Customer needs replacement and I can not find anything on these older units.Thanks
Dear Netpro gurus,My client wants to do call recording on their CIsco IP Phones (not for IPCC users, just normal users on CUCM 7.1). Got a question from the client asking regardless of which 3rd party solution they use out there, do they all need to...
| Subject | Author | Posted |
| 12-13-2025 06:42 AM | ||
| 12-10-2025 11:24 AM | ||
| 12-10-2025 05:17 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM |
| User | Count |
| 4 | |
| 2 | |
| 2 | |
| 1 | |
| 1 |
