Hey team,I need to pull the virtual machine for CUCM 8.6 off the UCS server, rebuild the server and then restore it. Does any have a link to the best practices for copying the VM off of the server?All replies will be rated!!
Hi all,This will be my first post here, though i do spend a lot of time going through these forums! I'm new to VoIP/Telephony, but have been working in networking for a while now. I have a problem though. One of our recent projects was to install a U...
Hello,so my understanding is that now the software for CUCM 8.x and Unity Express 8.x is free. You just have to purchase licenses now correct? Can someone tell me what the smallest number of licenses for each that can be purchased?Thanks in advance!...
Hi all,I'm wondering how I can do to import a csv file with the forward all field at "blank".Let me explain, on my import file I have some lines with a "Forward all" field filled and some others no, when I try to update my device profiles with this ...
We had an employee leave us and then come back. Her Exchange account was never deleted but her Unity account was. We reactivated her Exchange account but I cannot find the user through Unity anymore.They do not show up under Subrcribers that exist no...
Hello everyone,the need is for about 500 analog phones connecting back to to CUCM 8.6. Does anyone have a way to get that many analog phones over to CM using something other (read cheaper) than VG224s?Thanks in advance! All repli...
Hello everyone..We have a Cisco 3845 configured as gateway router with H.323.Now , we have DID configured in our network. Our IP phones have 2 lines configured one for Internal VOIP calls and second for DID outbound calls.Now, problem is in the DID c...
Hello,I have an stupid doubt but is a doubt!Can i build a cluster with one CUCM on VMWARE, an another CUCM installed in a MCS? The same thing with CUC!RegardsLeonardo Santana
Hi everybody.. I newby in cisco VOIP world.I would appreciate if someone could help me with the configuration of a cisco router trunk e1 between 2851 and cisco router 2911.Cisco 2911 has VWIC2-MFT-G703 card and Cisco 2851 has VWIC2-2MFT-T1E1.Regards ...
I have a CUCM 7.1 . which is a single SIP trunk & its working fine. But there is a new issue are arrige ......like . we have a IPTSP number like 096XXXXX.but i got new IPTSTP number like 096YYYYY. so is there any chance to do in a single SIP trunk i ...
Hi,I would like to verify my understanding for Cross-Server Sign-in functionality:Let's say we have two clusters as follows: Cluster_APilot: 1234UserA Cluster_BPilot: 5678UserBMy understanding is that the purpose of cross-server sign-in is that :...
Hi,I need to upgrade CUCM clusters from 6.1.4.1000-10 to 8.6.2a.I used the refresh upgrade procedure described in the release notes of 8.6.2a.We have to kind of hardware 7835-H1 and 7845-H2Theses hardwares are compliant with 8.6.2a for bridge upgrade...
Hello,I have a CUCM 8.6(2a) and Windows 7 64-bit PCs which have to use TAPI client.On each startup of the PC Windows UAC Feature has to be confrmed (see attached screenshot)I have seen lots of enties for UAC and CUPC or CUIC, but nothing for TAPI.Is ...
Hello,I need some help regarding the topic mentioned. Let me give a brief overview of my issue.My company has an IP Telephony setup in our office complete with a 3640 router and CUCM 6.0.1 with the router installed with two NM-2V and each module with...
Hi all,I am trying to ivestigate a problem wiht our E1 trunk with 10 channels. For some time we noticed that some numbers we dial out does not come through, instead there is a message on the screen of the phone Unknown Number. Afer analysing ...
| Subject | Author | Posted |
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM | ||
| 09-24-2025 11:48 AM | ||
| 09-19-2025 06:42 AM |
| User | Count |
| 4 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
