IP Telephony and Phones
Labels
dears,any one can help, i have these config in my translation rulesincoming calls are working when i dial 2837555 from outside , but some are saying that when they call from certain numbers the number 2837555 it will be busy.                   !voice...
Does anyone know the file name that is populated in the "Load Information" field on the Device Defaults page of CUCM 7.1.5 for an 8945 SCCP phone for firmeware cmterm-8941_8945-sccp.9-3-1-19.cop.sgn?joe.
Hi.         I need to configure route pattern in CUCM 8.0 in INDIA. Can any body tell me the route pattern for STD calls, International calls. And one thing is also what I need to configure to PRI to make outside calls. I have added the gateway to CU...
I`ve configured MVA as belowPABX, PSTN >>>>H323G>>>>>>>>>>>>CUCM7.0I  have it woring using the Mobile Connect with RDP all wokring - dial in via the PABX to an IPT handset1 on CUCM 7.0 the call then rings the IPT device and then rings my RDP. I`ve no...
iptuser55 by Frequent Contributor
  • 2985 Views
  • 10 replies
