IP Telephony and Phones
watch here Journey banner_1
Labels
Hi, I am getting an error (file auth fail) on 7940 ip phone which i got as the replacement. I have already check blogs on CSC and they are pointing to the firmaware upgrade. the phone shows app load id p00305000101 and in my cucm the device default a...
Hi I have in a CUCM 8 a Translation-pattern to a internal extension, this fails and the debug shows ´Unallocated/unassigned number´That extension is registered, and without any problem, i even test the TP with other extension, and fails again. The ca...
Hi all!Cisco phone 7960 is not receiving an ip add. We have tried a factory reset but both methods do not seem to work. DHCP requests sent to the router from this phone are ignored. Other phones are all functioning properly. Port configurations are c...
                   Hello everyone,can anyone tell me the correct part number for  a PRI card that goes into a 2800 series router and above?  I am coming up with 3 different part numbers, all different.Thanks in advance.  All replies rated.
how to check  how many aa sessions can be configured on cue?when i use the command"show license status application",it showing the license of voicemail and ivr only.thankskavi
