i installed cisco operation manager 2.0.3 with service monitor , the devices was added to DCR hence operation manager ,i cant see the network topology diagram in service level view page although i can see the devices in the same page
Hi,I have a quick confirmation question.We currently have a CUCM 8.0 cluster installed as virtual machines on Cisco UCS hardware.I will be doing an upgrade to 8.6 soon. I know that the upgrade patch is needed first.I don't think we need to get any n...
Hi Guys,I need some assistance o8s n Fax configuration. I connected ATA and its registered with Call Manager 8.6. External fax is working fine i can send and receive the fax but requirement is also to send fax from one local number like 1002 to 1009...
Guys!When making changes through the CCME GUI, I keep getting the error - Configuration change failed. Please report the following erro. No matched command.Am i missing sth here?
Hi All,I have several 9951's that I've added to CME 9.0. Users of SCCP phones are used to use the Speed Dial softkey. I need this same functionality for these SIP phones.I've read the Feature Policy Soft Key Control section in the Administation Gui...
We had install CUE 8.6 and it is working with Evaluation license, now we upload the permanent license and reload the CUE, but still the permanent license shows not activated and the CUE is working with Evaluation only.The screen print and sh command...
Dear NetPro gurus,One of my customers would like to migrate / upgrade their existing UC applications (like CUCM, CUC & UCCX) onto Cisco UCS Servers.They are just curious that is there any difference on the hardware in terms of "numbers of VM can be h...
Greetings,The corporate directory is slow to respond today after behaving normally since implementation a few weeks ago. On the older phones, 79[46]0, it functions normally and pops right up, but on the newer phones there is a 30 second delay. On ...
Greetings!I have a retail store chain that I'm implementing VoIP, and everything is working well with my current implementation plans EXCEPT for what I guess could be considered a failover scenario, although it's more like a mobility scenario for my ...
Hi,Can an IP Phone have/support a cable "splitter" that allows someone to eavesdrop on a call. If so, is there any special make / model?Customer is not lookign to you silent monitoring etc. They prefer the old fashion wayJ
Hello,I have an ASA setup with Anyconnect for VPN Phone. The setup works great on comcast but for some reason the phone fails on FiOS and we cannot figure out why. I typed the url the phone uses into a web browser: https://< ip address of ASA>/VPN_PH...
I have Quality Manager 8.5 installed and running with UCCX 8.5 and CUCM 8.5 in a test environment. I am working on an uprgrade and trying to make sure everything is working properly in test. I've overcome a few hurdles getting it trying to get it to ...
Good day, everyone!At last, i've created a h.323 trunk between CME 2901 and Panasonic TDE-200. Calls between local phones are dial well.On CME i have subscribers with phone number 501 and on Pan TDE-200 - 102. If I dial from 501 to 102 and from 102 t...
Hi all,Need your help, I am configuring the MGCP gateway do i need to configure the POTS dial peer for incoming calls.Can some one please help me here
Hi everybodyDuring boot process, cisco ip phone contacts tftp server and downloads its configuration file.This file contains “base level settings,” including items such as device language, firmware version, call processing server IP addresses, port...
| Subject | Author | Posted |
| 01-18-2026 05:39 AM | ||
| 01-16-2026 03:24 AM | ||
| 12-31-2025 01:52 PM | ||
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM |
