voice translation-rule 1rule 1 /^9/ //voice translation-profile 1translate called 1
Hi guysI'm with a big problem in my customerThe customer associate users (from LDAP) in owner ID (field) in the phones devices.Well, sometimes (all weeks), employees are, how can I say, they take a "job-licensed" (sick, accident at work and another c...
Hello,Was anybody solved this problem?http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCto3125669XX phones have 10 min TFTP DL timeout. Upgrade fails over WAN. Symptom:69XX model phones (6921, 6941, 6...
Hello,I had our telco company install a single PRI last summer. The PRI feeds 5 locations, all of whom we disconnected their analog lines and they now ride on our PRI line at Location A. I needed to setup 911 so that when calls originate from any of ...
Hi All, Seems to be a bad day with all sort of issues we have specific lines for our vice president (s) at our org, what exactly is happening is that intermittently for some of them , the roll over lines ( line 2..line..3 of the same directory numb...
Hello guys, does anyone have the release document for Unity Connection Version 7.1.5ES7.10000-7. I am trying to find out which bugs are fixed in this Engineering special. Cheers guys.
I am having a problem with a Hunt Group configuration I am running CUCM 8.5 with Unity Connection 8.5Forward Hunt No Answer is set to the Unity voicemail pilotForward Hunt Busy is set to the Unity voicemail pilotIn both the above scenarios,...
Hi,I have proposed 3905 IP phones to a customer along with CP-3905-PWR-IN= power adapter.I want to know whether CP-3905-PWR-IN= is a 2 pin power adapter or is it 3 pin power adapter?I searched the data sheets as well as administration guides but this...
Has anyone experienced this behavior?I am setting up call security in a cluster. I have followed the docs and configured the whole deal with eTokens, CTL file, security profiles, etc.So far, the 10+phones I am testing are encrypting the calls as expe...
Hello. I am currently trying to integrate a CME 7 with Untiy 5. Everything looks to be in order according to the documentation. However when a call forwards to voicemail it is sent to the main Unity greeting not the mailbox greeting. I can see in...
Hello everyone,running CCME 8.6 with older 796/40 phones that were originally on CME. Users are experiencing an issue when they hang up a call the phones will often go off-hook into speaker phone mode. They are not hanging up too hard or inadvertent...
Hi,I am not sure what is missing and all the default settings are made for the account undeliversablemessagemailbox and still i dont see the option to select multiple for deleting from the Inbox of the Cisco PCA Inbox.Please let me know if some thing...
All,I have some users on CallManager Express 8.6 that get a significant delay (1+ seconds) from the time they hit the speaker button to the time they get dial tone. The setup is phone--->3750 stack-------->ASA5510-------------->2911 running CME. So...
Hi All,I'd like to ask your support/advice for the following 'strange' behavior we're facing.As reported by "Cisco Unified Communications Manager Administration Guide, Release 8.5(1)", LDAP Directory Configuration section, the 'Phone Number' field sh...
We have two CME's. One has phones registered to it and the other has a PRI with backup POTS lines. Inbound calls from the PRI to the phones work fine. But when a phone on the CME tries to place a call across the PRI on the remote CME the call fail...
| Subject | Author | Posted |
| 03-25-2025 06:06 AM | ||
| 03-21-2025 01:42 PM | ||
| 03-20-2025 05:12 AM | ||
| 03-19-2025 06:53 AM | ||
| 03-18-2025 05:41 AM |
| User | Count |
| 5 | |
| 2 | |
| 2 | |
| 1 | |
| 1 |
