IP Telephony and Phones
Labels
I have an senario with hunt group and Unity connection. I am using Unity connection 8.0 and UCS 8.5. The senario is like this in the office hours i want call to go to call handler after 5 rings or when the hunt group is busy that is working fine.But ...
I have Call Manager 7.1.5  and  7960 phones  which will be set up as a community assets in common areas.  I  need to  restrict use of the phones  to a specifc group of authorized users. Active Directory and 802.1x are not available only local Call Ma...
All,I have a need to replace a VPN concentrator with another device.  The need is to terminate 10-20 VPN tunnels.  Voice and Data will be running over both.  The connections are using the Public Internet (no comments please, I already know).  Given t...
         Is anyone able to help with a problem i have installing the 7914We have the CCME 3.2 System with lots of types of phones, I have 3 7914 on 7961 phones1 phone is working with the 7914 on the 7961 - all numbers and buttons programmed the other...
How to forward all incoming calls coming through 10 channel PRI to remote SIP proxy server?I have cisco 2921 as cucme with E1 interface.There is no any user in the local network , so all call must forward to remote SIP server.Call is coming up to 292...
Dear allI have a MCS-7835H2when I want install CUCM 7.0 on it..after sanity check disk it give me thta hard disk test passed.but suddenly breake the setup proccess for an error.the critical error is : can not find bios file version 7835h2-2333 ini ha...
miskoolak by Level 1
  • 1384 Views
  • 7 replies
Hi,One of our cutstomer's cucm got stuck yesterday night and was not able to make outgoing calls. I do not know the status of the IP phones at that point of time, though the calls were not going. Then the cucm was hard rebooted and it got fixed. Its ...
khanfawaz by Level 1
  • 1249 Views
  • 7 replies
Dear Experts,I have CUCM 6.1 and IP Phones 7940 and 7960 and 7962, I was using NTP Server (which was not working well) so, I decided to remove it and Adjust the time from the CallManager manually, after I did, all phones were showing the correct time...
