Hi,I am new, I have to design a network with 8 port FXO, so I was wondering if the Cisco 2811 could support two VIC2-4FXO card?
Hello to all , I have a publisher, Subscriber recently added both have 7.1.5.30000-1 version. In the new building I have a Cisco 3925, what is happening is that when making a call from outside can not see who perform, does not display the caller ID
I have a scenario for a customer in Europe where they have 2 E1-PRIs, each PRI is configured to allow the first 10 channels to be only for inbound and remaining 20 channels to be inbound/outbound. If I send a call out on channel that is only allowed...
We are getting this error when trying to sync.2012-06-01 13:22:19,539 ERROR [DSLDAPSyncImpl(72515187-27b0-dc9e-01e8-5835e5f4c0d2)] ldapplugable.DSLDAPSyncImpl (DSLDAPSyncImpl.java:608) - LDAPSync(72515187-27b0-dc9e-01e8-5835e5f4c0d2)[Run] javax.namin...
Hello,I have a VIC-2-4-FXO that has two issues. 1) there seems to be a 30 second delay from when the caller hears ring back to when the IP set actually rings. 2) If the caller hangs up without being answered, the IP set keeps ringing for about 20 se...
Hi All,I am not a Cisco engineer but I would like to know if I am being given the correct information. If a client calls us on our external number for example, 0161 123 2000 my understanding is that number can be routed through to the device with t...
Hello everyone,does anyone have any examples or links they can show about QSIG between CM 8.6 and a Nortel system? Just need to be able to send and receive 5 digit calls between the 2 system.Thanks in advance! all replies rated.
Does Cisco make a VoIP phone that connects to the wired LAN (that is, the phone doesn't use wireless LAN 802.11 a/b/g/n) but does use DECT 6.0 for the cordless communications from the base station to the cordless handset? So, for instance, the 7921G...
When using call forwarding or single number reach to external numbers, is it possible to send the caller ID of the forwarded caller's caller ID in a UC 500? I've done this with CCM 4.0, but I don't know if this is a limitation with the UC500.
What's the easiest way to upgrade really old 7940 and 7960's hanging on an 8.5 call manager? They're booting up looking for P003xxxx images.
Can IP communicator V8 or any other version be installed on terminal server for users.Does it support terminal ServerSaima
Hello everyone,on Unity Express 8.5 I am trying to get the AA to play a particular prompt then play another prompt as a sub menu (might be the wrong way to go) without the caller having to hit a key. Prompt 1 is the "Thank you for...
Where can I find the downloadable Unity Express Script Editor? I have a CUE 8.0.6 and can'r find the Editor anywhere as a download on the Cisco download site.
I have an IP phone 8941 and the phone does not register under the clients or team or wan device pool in CUCM 7.1.5. I am able to register and configure the phone under the device pool Change_me_now and make phone call. the specific...
I am running the DMA tools, to upgramde CCM from the version 4.2(3) to 7.0 but I have the following errors: [09:05:39 AM] Validating exported Cisco CallManager database and directory data. [09:05:39 AM] This can take a long time, depending on the siz...
Subject | Author | Posted |
07-16-2025 12:00 PM | ||
07-15-2025 06:51 AM | ||
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM | ||
07-02-2025 08:49 AM |
User | Count |
4 | |
2 | |
1 | |
1 | |
1 |
