CUCM 8.5, Firmware 9-1-1SR1Phones have only one ring type and don't appear to log call history.Any assistance appreciated.Brian
Use 2 line phones: 1-line Primary DID DN, 2-line ACD DN for UCCX agent calls.Typically our agents(7940 phones) pick up the handset and select the second ACD DN to connect to queued calls. The 9951 phones won't allow me to answer the second DN after ...
Hello,I have an incident that one of our customer's UCS server C200 M2 has been down due to power failure. Since the customer location is too far out of the city it takes us some while to get there to run all the Vmwares (CUCM Pub,CUCM Sub, CUC) to w...
I have setup CUCM 8.5 for a client of mine. However I am stuck with a request which their own system (some Panasonic) can do and I am not sure if Call Manager is able to do the same.Client wants to be able to identify people that rings into the busin...
Dear,I need expansion module buttons to be work as speed dial, below is my configuration, phone cp-7962 buttons are working with speed dial but expansion module is not working??tftp-server flash:cmterm-7916.1-0-4-2.cop.sgntftp-server flash:B016-1-0-4...
We would like to make a setup where we can remotely change the Call-forward nr for a specific extention.Can somebody explain how this can be established ?Best regardsEddy Mulder
Dear all,I check cisco document and found that, Cisco CME 9.0 support ATA 187 to connect fax/phoneI try to config SIP as bellow :voice register global mode cme source-address 10.17.30.14 port 5060 max-dn 20 max-pool 20 tftp-path flash: create profil...
Dear NetPro gurus,My client has recently setup their CME on one of their offices. All phones registered fine and working, but we find that we can't connect to their CUE, not even the CUE Admin page.I have attached their config. The CUE should be ru...
Hello,I have IP phones converted to SIP firmware.i would like to know from where i can download the following files or sample of them so i can modify them as required:SIPDefault.cnf, SIP<macaddress>.cnf, xmlDefault.CNF.XML, RINGLIST.DAT and dialpl...
I have a UC500 with an AIM-CUE and I get many errors when I attempt to boot it up, so I am trying to install version 7. I have a Vlan that acts as the default gateway on the router, and am utilizing the IOS DHCP server, which successfully hands out I...
Hi to all .I have problem with AIM-CUE Script , when the outside caller dial-extension X and it's busy , they did not hear anythink indicate that line is busy , it's possible to make choice for caller "the line is busy , if you want leave MSG dial x ...
I try to configure a SIP IP 2n Helios on CUCM 7.1.3. But it does not register in Device-Phone - it is "Rejected". I use AD 2000 for LDAP authentication.1 . Dans System – security profile – phone security profile à I set the mode Enable Digest Authent...
Where is this field in the BAT tool so I can link up these users in Unity Connection?Directory Number AssociationsThanks!
I have an issue with the correct time being displayed on CIPC. There are 2 configured in the system and they both are exactly 4 hours fast. No other phone has this issue. The router has the correct time, NTP is accessible and working and the time zon...
Hi folks,My customer has a site in Sao Paulo / Brazil, for calls to the same city isn't needed to dial area code, but if I dial a near city with the same area code, the service provider is looking for area code before the number, ex: 114444-4444. For...
Subject | Author | Posted |
05-12-2025 12:06 PM | ||
05-12-2025 06:55 AM | ||
05-11-2025 04:59 AM | ||
05-05-2025 11:16 AM | ||
04-30-2025 05:24 AM |
User | Count |
5 | |
3 | |
1 | |
1 | |
1 |
