Does anyone know what the maximum amount of entries are (per user) for the personal address book feature.
where can i use answer-address command?. This is used in pots or voip dial-peer?dial-peer voice 1 pots translation-profile incoming srst_123456 answer-address 6320940!Thanks
hi,we have an CUCM 7.1.5 with some 6941 SCCP Phones. some of them have SCCP firmware 8.5.1 or 8.5.3. I can succesfully upgrade to firmware 8.5.4.No I want upgrade them to 9.2 and at first step to 9.0.2 or 9.0.3.But upgrade doesnt work. phone says [14...
Hello,I have a CME 8.6 running on a 2811 ISR.It is currently configured with Extension Mobility. Phones are all 7960.I want to implement presence and have followed the admin guide to do so, but I've come across a problemblf-speed-dial command. When t...
The backup of the database, voice messages etc are not being backed up. We use the network to pull the tar files to another server using FTP. Currently I believe the file(s) might be too large and I am getting errors on the backup history. althoug...
Hi team, There is a new feature called SWAP (Toggle between two existing calls) for the 6900 IP phones, I want to know if I can activate it in a Call Manager express solution and how I could do it.RegardsJose
Hello people,I am trying to configure my CCME router (2901 with one PVDM3-256) to make hardware conference calls. I tried yesterday software based and it is working great. But as soon as I press the flash button to integrate the fourth participant I ...
I have a client about to deploy Avaya IPT and they are asking about QoS on their Cisco infrastructure. I've been doing research but almost everything I find is very old..2007..2005. Does anyone know of up to date documetns or is anyone willing to ...
Hey Everyone,My boss mentioned to me that he wants to start making backup's of our cisco voice enviornment. Currently we have 4 servers.1) UCCX2) Unity3) UCMPU4) UCMSUBAll of these servers are build with a RAID 1 mirror. He mentioned that typically...
My CEO asked me to mask his name and number when calling to internal DN, I've been checking on the manual, but I couldn't find nothing like this. I'm able to hide or change the name, but the DN always appears in the bottom of the name between parenth...
I am looking for a way to setup bulk speed dial in CUCM 8.5 for 400 numbers. Does CUCM has search option available for speed dial? I want to setup all phones at sites with speed dial that lists all 400 numbers. Cisco only support u...
Hi,I need also encryption between CUCM and SIP Gateways. So, I configured the SIP Gateways only the command "SRTP" globally, and the "SRTP Allowed - When this flag is checked, encrypted TLS needs to be configured in the network to Provide end to end ...
Hello,I need some clue to configure the VPN feature on CUCM 8.0.2 with ASA 8.0.5I got the the guidelines but i need the more info about the config on the ASA.http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/8_0_2/secugd/secvpfet.htmlHow ca...
Hi all,I'm looking to see what possibilities I have for adding a few analog phones to my IP phone network. The phone network comes into an Avaya IP PBX, that also has FXS(?) cards for several analog lines, but I need to know what to look for to see i...
Hi, it is possible have a CUCM 8.5 version cluster without dns?, when installing the second node it ask for the hostname of the primary server and this option can not be skipped, i tried using only the ip address but it was not possible. ...
| Subject | Author | Posted |
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM | ||
| 09-24-2025 11:48 AM |
| User | Count |
| 5 | |
| 3 | |
| 2 | |
| 1 | |
| 1 |
