IP Telephony and Phones
Labels
Dear, I bought this used device and already managed to update its firmware to SIP, it's with version SIP70.9-2-1S, and it's working perfectly with Asterisk. I need to configure the softkeys to make the device as simple as possible, since it will be u...
MRP-BR by Level 1
  • 705 Views
  • 0 replies
Dear, I bought this used device and already managed to update its firmware to SIP, it's with version SIP70.9-2-1S, and it's working perfectly with Asterisk. Now I would like to configure his interface for Brazilian Portuguese. All material I find say...
MRP-BR by Level 1
  • 436 Views
  • 0 replies
  • 5 Helpful votes
Have a remote site whose DID's reside on a router at HQ.  This is also where the CUCM cluster resides (HQ).   Calls from PSTN to users direct number have a consistent issue where the caller can hear them, but the users cannot hear the caller.  If the...
Hello, I was asked to provide a solution for following scenario---There are 2 DIDs -1111 and 2222. Create a hunt group for calls to 1111 and if all agents are busy,  queue the calls and play a message after 1min saying someone will be with you shortl...
G3261 by Level 4
  • 885 Views
  • 4 replies
Greetings, I am having problem with registering SIP Phones 7811, 7821 series.I got some SDL logs from the CUCM and the error I am getting after I try to register the phone with a secure SIP profile and install/upgrade the LSC is this: SIP/2.0 403 For...
