Resolved! Quickly find VG224 port based upon DN?
Client has multiple VGs. There is an issue with an analog paging line. Is there a way to quickly cross reference to find the VG port when all I have is the DN? CUCM 6 cluster.Jeff
Hi,Our caller ID is showing less digits.For example:International call from +390650956280 is displayed as 650956280In country call from 0607353129 is displayed as 607353129.Version: CUCM 7.1.3Regards,Amit
Hey All , I have issue with MOH service on CUCM 7.0 .The issue appear when I try to put some one on the hold ? some time the one how on hold he can hear the music and some time he does not hear the music . i did restarted for some serivces relate...
Hi, i have a Callmanager 4.x with unity 5.x system connected to an asterisk pbx via sip trunk. Formerly i can transfer incoming calls via unity to any extension in asterisk, using dummny internet subscribers for each extension. Afater an outage this...
I have an extension which I want to use only for internal dialing. Local dialing outside the company from this ext should not be allowed. Below is the configuration for this ext:ephone-dn 120 dual-linenumber 120 secondary 000000000 no-reg primarypick...
When we try to enable the "service module Embedded-Service-Engine 0/0" router displays the message below:Memory size doesn’t meet the requirement of Embedded-Service-Engine 0/0.The ISM-SRE-300-K9 already have "4-GB internal USB flash-memory module". ...
Hello guys,I registered 9971 and CIPC+CUVA to CME 9.0 (c3900-universalk9-mz.SPA.152-2.T1.bin).I also have a CIPC+CUVA registered to a CUCM 8.5.1.10000-26.I try H.323 trunk and SIP trunk to connect the CME and CUCM. CME CIPC+CUVA works flawlessly, it...
HI,what is SIP 183 response ? can I confige it on the cisco gateways ? I think it is used for call queueing
I have a customer that want to disable touch tones on some of their c7912 phones on their CUCM 7.1.3.They don't want to disable DTMF, they just don't want to hear the tones when they press the buttons on the phone.I've tried to look for a solution on...
Dear All,I have configured the CME 7.1 on my as5350 with the IOS 12.4(22)YB, but the telephony-service in not enable in the configuration mode , I could not access the telephony-service mode . why this problem occures? is it need a preconfiguration b...
Hi,I have some issue while registering a third party ip blue softphone with CUCM 7.0 installed on Vmware workstation and i want to register ip phone with cucm through GNS3. but ip phone is not registering with CUCM its showing the status Unknown in C...
Hello All. We have a call manager business edition server with contact center express setup and I am in the process of testing our SRST system. I am currently running SRST in fallback and noticed that I do not have the option to create hunt groups wh...
Hello,My inbound and outbound calls are having some weird issue, been trying to troubleshoot for days now, but can;t seem to resolve this issue.. Have changed the configs over and over looked at the logs countless times but without any positive resul...
Hi, I am new to cisco and this forum. Currently we have a 2821 router connected to 16 ATA186 devices. This is being deplyed on a client site and we have to add it to their existing rack system. They are looking to have both data and voice on site. Th...
I have a UC560 with PRI setup at the primary site and like to setup another UC at a remote site. What's the easiest way to change the default IP address of CUCM and CUE for the remote UC?The 2 sites are connected via MPLS. Can the remote site have a ...
Subject | Author | Posted |
07-15-2025 06:51 AM | ||
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM | ||
07-02-2025 08:49 AM | ||
07-01-2025 09:51 PM |
User | Count |
2 | |
2 | |
2 | |
1 | |
1 |
