IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 1224 Views
  • 6 replies
We have 2 buildings that are connected via fiber. Building A has the voice gateway and CallManagers attached to it. We would like to put another gateway in Building B with 2 POTS lines hooked up that way in case of a fiber cut or outage that building...
Hello experts,We have some old MCS7825-H3 servers with 2GB RAM memory we need to upgrade to 4GB.I was wondering if there is a particular way to perform the upgrade:- Do we only need to power the server down and then install the modules?- Is a particu...
Dear. I have a problem with the IP phone model 2970, which at times does not receive energy and block, and to solve this problem momentarily preciona 3 times the number 3 and up again, my question is why this problem occurs, and how I can fix it? tha...
Hi all,I have problem uploading audio files for MoH. When I click Upload button, popup page hangs with blank page and stays that way. Tried to reset MoH servers, streaming services... Nothing changes.Has anyone encountered ths behavior? Any help/hint...
Resolved! need help on unity
hi all,i am new to cisco field, i have configured a call handler which transfers to subscribers phone and also playing message like welcome...... but the issue is after playing that greeting it is redirecting to voice mail box , can we prevent that ?...
commonman by Beginner
  • 302 Views
  • 1 replies
I came across this on Cisco site, when searching for configuring our 29xx router as a redundant when the callmanager fail:"In a single-server configuration, there is no redundancy unless Survivable Remote Site Telephony (SRST) is also deployed to pro...
Hi Voice Team, I have a SIP integration between Cisco CUCM and Siemens Hipath. I have the environment working properly via g711, but I wuld like to work with g279 and it is not working... My environment is: CUCM ---- Router (MPLS) ---          MPLS  ...
Hi,We are in the process of planning the upgrade of our CUCM servers and as part of this they will have new IP addresses.  A challenge we have with this is our CIPC's point to the old servers for their TFTP entries.  Is there a way to centrally updat...
