Is there a way to remote and bulk update Cisco 79[46]5 phone displays. My searches never bring me to anything useful and in my mind this seems common enough to be asked before. I have 100 phones which instead of the default image the request be m...
Hi All,We have implemented QFINITY voice recording. There are 2 remote offices through a VLAN and this VLAN is being monitored on a port of a 3560. In this port, the QFINITY server is connected. The problem is that phones of these remote offices are ...
I wanted to Change voice message recording format from G.711 mu-law to G.729a but in order to do this I need to: get this sl_g729a_setup.exe fro mthe cisco unity connection utility dvd (8.5 or 8.6) where can I download this dvdTo Install the G.72...
Hello,I am still getting details but wanted to see if anyone has seen thisIn ViewMail 8.5 if you have a message highlighted then go create a Word document and send it as an attachment the VM message that you had highlighted gets sent along in that s...
Dear Friends,I have a question regarding route List...I am trying to apply some digit manipulation for some Route Groups assign to a route list but I could not find "Pre-Dot" in discard digits field for called party transformation, only NANP digit ma...
Hello All,I have to change the local interface for sccp on our voice gateways and can't find a doc that lsits the step you need to do for that, doesn anyone know the correct procedure?I need to change it from Loopback to a BVI interface.Thanks.
Hi all,I need to know if anything can be done about this problem I have with a customer of mine.They have a DDi number that they want to control the amount of simultaneous calls that come in at any one time based on predefined time periods.I have H32...
I have a polycom registered to Callmanager 7.1.2. Does anyone know where I can finddocumentation on the 3rd Party SIP basic calling features. I have a Polycom confernce phone and wouldlove to do meet-me or ah hoc conferencing.Right now I only have li...
Has anyone successfully registered a Polycom IP 4000 soundstation with Communication Manager7.1.2 or any other version for that matter? I've followed the "Configuring 3rd party SIP devices" documentation located here: https://www.cisco.com/en/US/docs...
Anyone ever get it to work with CUCM?Anyway to DL SCCP firmware to it or Am I going to have to go SIP
How can I do this? All of the direction I find seem to use some other GUI interface and I can't seem to migrate it to CCP.
Why we assign a CSS on gateway added on Cisco CallManager?Thanks
Can anyone tell me that what does router pattern does starting from \+. I am using Cisco CallManager 7.1.5 but inever use this patterns having \+. Thanks
Hi there,A client wants to implement Extension Mobility, in order to block access to certain destinations and unlock via PIN, and is using the Line CSS to implement restrictions on the calls destinations. I wanted to export all the line configuration...
hi,CitA----------------------CityB(This contains voicegateway,unity and ccm)City has one number 0123456 while i call that number it is redirected to cityB PRI.City B has unity where call handlers has been configured.When i dial cityB the calls fwd t...
| Subject | Author | Posted |
| 03-04-2026 06:20 AM | ||
| 03-02-2026 07:40 AM | ||
| 03-02-2026 07:34 AM | ||
| 01-16-2026 03:24 AM | ||
| 12-31-2025 01:52 PM |
