IP Telephony and Phones
Labels
hi all,i need help in unity plzforwarded calls to untiy then i passed the call to call handler by forwarding rule which transfers calls to subscribers with caller input ,now the issue when i am dialing extension which i forwarded to unity playing mes...
hello guys,i am running cisco unity connection 7.1.5 with regular scheduled back ups to an sftp server. the problem is sometimes the backups just fail.what happens is that a back up is done for some files but others are not done. I checked the storag...
abukuru95 by Level 3
  • 1535 Views
  • 4 replies
All,I think I know the anser to this question, but I don't have access to a VG-202 or VG-204 to confirm. I have a need to run a TCL app on a VG-202 or -204. I know the app will run on a VG-224. I read a datasheet which says something along the lines ...
Got a question  When I create a moh , the base multicast lets say i use 239.1.1.1 , If i  create 5 music sources in order so the g711 for source 1 would be 239.1.1.1 , the g711 for source 2 would be 239.1.1.5 etc, now when I set up a router for multi...
miket by Level 5
  • 912 Views
  • 5 replies
