IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5783 Views
  • 14 replies
Dear All,Ive been trying to get my VGW (Voice Gateway) registered with my CUCM_7.1I need to add the isdn bind-l3 ccm-manager in my serial interface. BUT THIS COMMAND IS NOT SUPPORTED The only command similar to this is isdn bind-l3 q931.I tried chang...
I have a capture of a failed outbound fax call via SIP.  Sometimes the calls work and sometimes they don't.  I have attached the captured and wanted to see if someone could review the debug to help determine would could be causing the issue here.  Th...
Resolved! FXO vic problem
Hello there!I'm testing a cme and everything works fine. FXS works great and i can do all internal calls without any problem. Now i have this issue: i got a external line  with no function besides gives me a dial-tone (when i plug this line into a an...
I have a client looking for a Ip Tlephony Deployment in their company for 180 users based on this requirement i have requested for the MCS7816I4-k9-cmc2 with cucm8.6 qoutation and pricing from the cisco partners they have advice me to go with MCS7835...
johntim20 by Level 1
  • 456 Views
  • 3 replies
hi all,here is my scanrio,i have 2 uc560 devices and each side we have pri trunk connected and i connecteed these 2 devices by h323 trunk , so i can call extension both side.but i need to access remote pri trunk from site Alike from site A we need to...
zeuscyril by Level 4
  • 325 Views
  • 3 replies
