Hi, We got an error at ccmdb part while getting a backup of callmanager (publisher and subscriber on MCS 7825 servers) . Error message is in attachment. Does anyone help me to resolve this issue? Thanks...
Please help me out, do I need analog license to register each analog phone to CUCM while using VG224? Please give me any cisco link for reference.
Hi,Cisco Voice soltion required for one of our customer.They have 80 users.they need meet me ,mobile support,call reporting ,auto attendent ,call conferensing facility.They are using 24 analog linesso which device i can suggest for them? anyone help ...
Q.What dial plan element changes the dialed digits? Q: What dial plan element is used to match dialed digits for routing?
Hi,Any available cisco tools or any plugin or any third partly tool available for notifying the changes done in communication manager.Changes like: Systems Elements: Servers, Device Pools, License, etc.Media Resources: Conference Bridges, Transcoders...
Dear Team,Kindly assist with this request, as I have really old Speed Dials (from at least 2 years), and most of them are out-of-date.I have a Cisco IP account, I know where to go to update the Speed Dials (URL below), but I can't remember my origina...
I was wondering what folks prefer as far as equipment goes when connecting a not-tiny amount of analog devices to a Cisco IP environment. We currently have about a dozen ATA186's spread across 3 server rooms, and while I understand the pain it'd tak...
Hi,I have configured up an 8941 IP phone into our CM version 7.1.5It appears registered in CM, but it is running the original firmware load and has not downloaded and installed the latest load 9.2.2.0 onto the phone. It can also make internal calls b...
Hi All,We have Using CCM 4.0 .All the Call from out side will Come to the Reception IP Phone (Model 7940). From there We are unable to forward the call to my mobile. From Extenson we are able to forward the Call to mobile ThanksRoopesh
Is it possible to generate a message similar to "you have reached a non-working number" from within CUCM? We have a DN with corresponding DID and need CUCM to generate this message. I have tested and in a pinch we can just utilize the Telco-generated...
Cisco Unified CM ver8If a user doesn’t have a voicemail box and forwards unanswered/busy calls to another extension the call returns to the original extension if unanswered/busy but there is no voicemail box.How can I make the call terminate at the s...
Hi all,I'm new to the IT and Cisco phones environments so fairly unfamiliar. I'm making this to see if a clients request is possible after looking around for a few hours with no clue if the search is in vain.We have Cisco IP Phones 7945s. We use C...
Recently added a shared line to several 7942's. Now when the messages button is pressed, I get "Hello, cisco unity connection messaging..." instead of prompting for the password for my primary extension. I have to hit "*" then put my extension in et...
hi everybody we have 1 cluster with 3 CUCMs with the release 6.1.3 and the CUCM reporting send the alert with The os version on all servers do not match , historically the had to install 1 Pub (HP) 1 Sub (HP)an 1 year after we had 1 Sub (IBM) more ,...
Hi everybody. Could anyone give me some pointers on what works for them when using a standard analog line connected to an FXO card on a Cisco 2901 gateway, MGCP controlled by a UCM BE 5000 8.6? The fax machines are connected on an FXS card in the s...
Subject | Author | Posted |
06-19-2025 08:23 PM | ||
06-17-2025 07:43 AM | ||
06-17-2025 06:11 AM | ||
06-09-2025 09:11 AM | ||
06-05-2025 02:29 PM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
