IP Telephony and Phones
Labels
Hi,I am planning an upgrade from CCM 4.2.3 to CUCM 8.5 on new servers.I have upgraded to CUCM4.2(3)sr4b with 8.4.1 firmware, which can go to 9xx.Connecting IP Phones (7911 and 7941/61) on CUCM8.5 Ip phones upgrade to 9.2.1S and then connect to CUCM8....
Hi,I have the following scenario:analog fax ----------------------  VG202  ------------------- CUCM (8.0.3a) -------------------- 2821 Gateway (12.4(24)T4) ----------------- PSTN                            analog                             MGCP     ...
m.ranger by Level 1
  • 1138 Views
  • 2 replies
I hunted around and could not see if there was an easy way to do this:Route Pattern 5555 ----->SIP trunk------>PSTNOn the display, can it show 5555 - PSTN, instead of just 5555 of the called party?   I know in Unity when you connect to the VM server,...
Hello guys,    im getting empty CDR files. All I see is the headers but no information of calls is available. The CUCM version is 8.0(2). I checked all services associated with CDR and are enabled. What else should I look into? Thanks.
fuhrersk8 by Level 3
  • 1208 Views
  • 3 replies
