IP Telephony and Phones
Labels
I was poking around to see if there is an application for click to call for CME.  I see the Unifed Call Connector and I did get this to work ok.  But it does not have the ability to dial from a webpage unless I missed something.  Or does it require t...
My customer is running CME 8.6 with 7942/7962 phones.  The most recent info I can find on CCO (the CME admin guide) indicates that Abbr Dial softkey support is restricted to phones other than what he has.  However, when he uses the config shown below...
Hello Experts,We are going to have a power shutdown this weekend. Is there a way to gracefully shut the CallManagers down before the power goes down?  Also, when the power comes back up, will the servers automatically power up and come online? Is the...
Hi,I am planning to implement two SIP gateways/CUBEs at SITE A and site B for redundancy PSTN callings .  This will be implemented on CUCM 8.5x and CUBE routers are 2951 with IOS 15.x.which option is bettter?1. to put two SIP gateways into one route-...
pxh by Level 1
  • 934 Views
  • 3 replies
Hello,I am looking for information to configure a VG202 (Version 12.4(22)T5) to do secure call between an analog phone and an IP phone.It is specified that the VG202 supports SRTP (http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data...
Hello,Here is the scenario ,  I have following dial-peer Dial-peer  voice 1000 pots Destination-pattern 9........ ( 8 dots)Port 0/0/0:15Dial-peer voice 1001 potsDestination-pattern 9T Port 0/0/0:15When i dial 9 1111 1111 11 then call is matched to di...
Hi,   I have the following dial peer configuration on an h323 gateway: dial-peer voice 1 pots translation-profile outgoing isdn_map destination-pattern 911$ progress_ind setup enable 3 progress_ind progress enable 8 incoming called-number . direct-in...
Hi, I've an issue with call forward all to external number on CME 8.6, when I make a call from PSTN number to an ephone-dn which has call-forward all to pstn number no problem but when I make a call from an internal number to the same ephone-dn the c...
lguyomard by Level 1
  • 2381 Views
  • 4 replies
Not sure if this is the right spot to ask this question?I attempted to upgrade a 7940 SIP phone to SCCP.I think I got my upgrade version wrong, the SIP image on it was "P0S3-06-3-00"I attempted to put SCCP 6.0.5 on it. I think the SCCP image was too ...
