IP Telephony and Phones
Labels
Hopefully someone can answer this.  I am on CUCM 11.5 and CUCA... I have a directory handler set up for our main call handler.  My CEO would like it if when someone spells her name in the directory and chooses it, that it goes to her AA's extension i...
plavin001 by Level 1
  • 636 Views
  • 2 replies
Hello together We are currently changing the Telephony of one of our customers from analog to VoIP.We have already used the ata 191 several times and are very satisfied so far. Now the customer has a doorbell, which is connected to the analog System....
anzel by Level 1
  • 4664 Views
  • 8 replies
    I has a centralized UC infrastructure with only two CUCM and remote sites with Cisco 4321 voicewayand some 7821 IP phones. The PSTN is linked to the gateway with an E1 on the local sites and the gateway uses H.323 to the CUCM. There is one DID to...
yuexp0929 by Level 1
  • 1852 Views
  • 4 replies
  • 5 Helpful votes
Hi I was wondering if it is possible to Select "Forward All" and then select a speed dial number and have the extension forward to the corresponding Speed Dial Key? I tested and it works on a regular number or extension. The issue I am having, is tha...
Gando by Level 1
  • 545 Views
  • 1 replies
