Hello All, I am using Cisco call manager 6.0 and i am using public IP on it.I configure it well now my phone are registered from every network but i have one problem that my voice is going but i can't hear the another side voice. On ...
Guys,I am having this issue and i just need to verify, or justify to the telco that my configs are correct and the issue is maybe a loop on their switchingi've tried changing isdn switch-type and related configs to primary-net5 as this is E1, but no ...
Hi,i have a little problem with MWI. If i have new phones it doesn`t work. It works only if i enable a notification device and make a call to the voicebox. After that i can remove the notification device and it works with the phone. But it is annoyin...
Problem Description : We have got a cisco ip phone user whose DID was previously being used on a Turret phone , we configured the same extension on the Cisco phone ( and removed it from the turret phone ) , but the issue is that when an inbound exter...
Hi,We need to connect expansion module in 7961 phone model and then need to configure in Call Manager.Could you please help me out here how we can configure the expansion module in Call Manager.Expansion Model : 7915 UC Phone Grayscale Expansion Moud...
Im trying to test adhoc conferencing on a newly installed phone system (UCMBE 8.x).I'm using the following steps:Dial participant 1, establish callpress confrn buttonDial particpant 2, establish callpress confrn buttonWhen I press the confrn buttton ...
We have intagrated our 5.1 CCM with Microsoft's AD, however when we try to login to the ccmuser page we get an error saying "Access to the requested resource has been denied"I have setup "LDAP Authentication for End Users" but still no luck.
Odd issue--new CUBE implemented, same configuration as several others i've implemented with no issue, same provider. What i'm getting though is on the new trunk, the DID of the phone shows up as the inbound caller-id...haven't seen anything like thi...
hi,witth the cisco phone designer it is possible to upload new images on custom phone and not for all users.How could i do this without the designer?I found only this doc https://supportforums.cisco.com/docs/DOC-11493 , but this is for all users in t...
Hi All,Please tell me how to trace the call in CUCM..i want to know when user call from the ext to any number ,How dialed number is translating and wich path(Route pattern) it is taking..
Hello,there are phones A and B (both with voicemails) and A is forwarded to B. Is it possible to make that when B does not pick up the call, the message will be left in B's voicemail?
Hi,I have the following setup.Siemens PABX - VG30D DPNSS/QSIG Converter - 2811 MGCP GWay - UCM V7.1.3 ClusterThe scenario is:IPT Ext 8100 and 8101 are in a Call Pickup Group.PABX Ext 2000 calls IPT Phone Ext 8000. Ext 8000 transfers call to an IPT Ph...
HiWe are using FXS port for external paging,it is conected to speakers.It is hanging multiple times, it is going to off-hook state when user stops paging again it is not comming to on-hook state,when i shut and unshut the port it is comming back to o...
Hi,i am trying to set up a sip trunk on a 2901 CCME.this is my sip-ua conf:sip-uacredentials username xxxxx password xxxx realm small.eurovoice.roauthentication username xxxxx password xxxxnat symmetric role passivenat symmetric check-media-srcno rem...
Subject | Author | Posted |
06-19-2025 08:23 PM | ||
06-17-2025 07:43 AM | ||
06-09-2025 09:11 AM | ||
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM |
User | Count |
2 | |
2 | |
1 | |
1 | |
1 |
