IP Telephony and Phones
Labels
Hi,I have 2-doubts1. I have installed CME 9.0When using max-ephone command , I found a license agreement on the router for 60-dayswhen I show license detail cme-srst after that, I found it'll remain for 8-weeksI have the license paper for the CME but...
Dear Netpro gurus,One of my customer wants to buy a brand new Voice Gateway 3925.  If i buy the Voice bundle with the CUBE license, can the Voice Gateway then do CUBE??Voice Gateway 1 x C3925-CME-SRST/K9CUBE1 x FL-CUBEE-100=  1 x FL-CUBEE-25=I really...
huntl by Level 1
  • 528 Views
  • 1 replies
Hi All,I would like to try to implement T37 S&F on a 2951. However, my PRI is already binded to an MGCP gateway to CUCM, which means the dial plan will be ignored on any incoming calls, so I can't get the call to the onramp script. Is there a way to ...
dmurray14 by Level 1
  • 619 Views
  • 3 replies
L2 mutlicast moh is not working, i have setup RP and Gre tunnel, L3 multicast moh works fine for internal calls, PSTN phone calls hear only dead air.cucm version 7.1.2  gateway : mgcp, gateway 2851appreciate your comments
m.ateeque by Level 1
  • 1239 Views
  • 7 replies
Hey guysWe have 2 problems with two of our Callmanagers.We are using one CME (running on a Cisco 2911) and one Cisco Unified Communications Manager Business Edition, both are connected via IP.1. problem CME to CUCMThe problem is when someone from the...
