IP Telephony and Phones
Labels
HelloI am trying to run CUCM version 8.0 on a VMware workstation 6.5.2. The VM Boots up getting me the prompt username and password.But I cannot connect using URLthe network interface on VMware  is configured as Bridge : Connect directly to the physi...
Hi,I am currently running 8.5.1.13900-5 which is 8.5(1)SU3 and trying to upgade to  UCSInstall_UCOS_8.6.2.20000-2. I checked the Cisco Unified Communications Manager Software Compatibility MatrixI can directly upgrade to 8.6.2.20000-2 but I am gettin...
Hi,I am planning an upgrade from CCM 4.2.3 to CUCM 8.5 on new servers.I have upgraded to CUCM4.2(3)sr4b with 8.4.1 firmware, which can go to 9xx.Connecting IP Phones (7911 and 7941/61) on CUCM8.5 Ip phones upgrade to 9.2.1S and then connect to CUCM8....
Hi,I have the following scenario:analog fax ----------------------  VG202  ------------------- CUCM (8.0.3a) -------------------- 2821 Gateway (12.4(24)T4) ----------------- PSTN                            analog                             MGCP     ...
m.ranger by Level 1
  • 1335 Views
  • 2 replies
I hunted around and could not see if there was an easy way to do this:Route Pattern 5555 ----->SIP trunk------>PSTNOn the display, can it show 5555 - PSTN, instead of just 5555 of the called party?   I know in Unity when you connect to the VM server,...
