Hello All, I have setup phone proxy with my Call Manager. The Phone registers fine with Call Manager and I am able to call offnet numbers and internal extension when using my proxy phone offsite but I have no 2 way voice. What could cause thi...
Hello everybody,To have the VG224 operational in SRST, i configure it in SCCP on the CUCM.If i use MGCP to configure VG224, can i have the voice gateway registered on the GW in SRST ?Thanks,Matthieu
Hi all,Is there any slide (ppt) for CUCM Présentation for persons who doesn't understand IP TelemphonyWe need them to explain more efficiently to customersWhat is really CUCM What is really CUnity ConnectionWhat is realy UCCxWhat is PresenceWhat is O...
Hi,I am currently trying to adjust our pick-up groups on Cisco Call Manger 6, we have had some recent structural office work done and 2 departments are now merged into 1.I currently have 2 pick-up groups configured for each department, i.e. Group 1 f...
Hi Can you please provide the steps required to configure integrated messaging on Unity Connect 8.5?What are the instructions/steps for configuration of IMAP on Exchange 2003 for integrated Messaging?What tasks need to be configured on Unity Connect...
hi all,I would like to know how to set priority for Higher executives IP Phone to get register first in srst mode.
i am loading a Lab Server 7825 H1. As the install goes along, it asks for Network Connectivity. I have server connected to a 3650 Switch with my Test VVLAN 251 on the port. the Port is up/up.My question is what is the server looking for, as it with...
Having some trouble configuring a SIP trunk with Nexvortex on the Cisco UC520. Seems to be an authentication or NAT issue. Probably something silly. Wondering if anyone in the community offers paid remote / phone support for the UC500 platform, id...
I am cureently trying to get modems to work over an SCCP VG224 with CallManager 7. At present the modems can recieve but cannot send. The PSTN gateway they are using is MGCP and everything is configured for Modem Pass through end to end. Has anyon...
I recently installed a new server in the cluster, and this new server registers all devices (with the publisher as backup).It was working for two weeks and found out our team did not enabled the CDR ENABLED FLAG to true, so our billing app server has...
When upgrading from say 7.1(3) to 8.x, is there any technical reason or legal obligation to convert your DLUs to UCL/CUWL? I have read some postings that state you can continue to use DLUs until CUCM 9 when Cisco will force you to use UCL or CUWL li...
Hi all,How do I extract / install CME 8.6 router flash? I have experiences on 7.1 and below which the file formats are tar. Later versions are in zip format. How do I extract them to flash. Please assist.Best regards,Lawrence Chew
Hello,I would like to ask if it's possibile using Iphone with Cisco Mobile 8.1 to make video calls.If yes can someone tell me how is it possibile ?I'm using Iphone 4 with iOS 5, CUCM 8.5 and Cisco Mobile 8.1Thanx in advanceMarco
HI,I have Cluster (5 SUB and 1 PUB) version 8.0.3.22900-5. Customer ordered a new subscriber for some remote sites. I need to add the new server to the cluster and as you know this 8.0.3.22900-5 is not bootable and cannot run in new installation. ...
| Subject | Author | Posted |
| 03-26-2025 12:17 PM | ||
| 03-21-2025 01:42 PM | ||
| 03-20-2025 05:12 AM | ||
| 03-19-2025 06:53 AM | ||
| 03-18-2025 05:41 AM |
| User | Count |
| 5 | |
| 2 | |
| 2 | |
| 1 | |
| 1 |
