IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5865 Views
  • 14 replies
Whenever someone dials a person locally, the receiving phone shows the same number ringing on both the primary line and the on hold line. It looks a though the calling phone is calling the same number twice simutaniously. The dialed phone goes to voi...
wesleyj84 by Level 1
  • 349 Views
  • 1 replies
Hey all.I changed a 7912 from sccp to sip.  It was reported this phone worked 100% before the software change...Now..  Only the softkeys, up and down arrow, volume up (the volume down key does not work), and headet off hook appear to respond when you...
rbblue234 by Level 1
  • 607 Views
  • 3 replies
Hi AllI would like to have a UC520 automatically reboot (by applying some command on configuration) after every 2 or month continues running and set a time and date frame.because we have few customers with UC500, UC520, after 3 months they cant make ...
Hello,If running UCM 8.5 and I have an H.323 gateway (a 2900 series router with an FXS card) what do I need to do on CM (and possibly on the router) to route a number out of one of the FXS ports?  A paging system is plugged into the FXS port so the e...
