Cisco 9971 and BLF for call lists
Hello,does Cisco 9971 support BLF for call lists?It supports correctly BLF speed dials, but it seems it doesn't works with call lists, corporate directory, ...Regards.
Dear Brothers,I am having this project for IPT inetgration with other vendors. Does the 3945(CISCO3945E-V/K9) router option support all E1 with no blocking at all? My Project requirement wants gateways to convert and route voice traffic from huawei ...
I have a sccp controled vg224 fxs port connected to a valcom 9940 paging unit. When the ip phone hangs on the paging device the port generates dial tone followed by fast busy and reorder which is broadcast over the paging system until i reset to port...
I have a CUCM 8.x cluster ,which was initially had a 5 digit dial plan for internal and 10 digit for external . I have converted the dial plan to e.164 global pattern . For the internal users I have created a translation pattern to convert the 5 to 1...
Created a DN and added it as secondary extension a existing phone. Got mailbox setup but can't access it for the initial setup. Getting the following"for security reason, initial access to this mailbox can be done from the primary extension"Any other...
Hi All,We have 3 CUCM clusters. We use five digits for intercluster calls but for now we are using num-exp to send calls to the PSTN network. When I call from EU cluster to North America Cluster some strange digits get added to the extension which I ...
Hi Everyone,I have two MCS7835-I3 servers (publisher and subscriber) , we are planning to use the two ethernet ports , with the command:"set network failover"But , I want know which MAC address , should I use? I read with Unity Connection , I should ...
HI All , we have callmanger 5.1.3 integated with Active Directory 2008 , the problem is i am unable to import all user from AD , LDAP is synching properly but i can not import more then 312 user , what could be the issue ? is there any compatibilty i...
is there any possiblity that one cisco ip phone (lets say 7962) could be connected to different Call Manager. I am not talking about fall back scenario. It happens when links gets down..
Hi All,Although I have configured the Network clock select and participate but I still get slip and line code violation errors. Here's the config that I have in the GW.network-clock-participate slot 1 network-clock-participate slot 2 network-clock-se...
Hi,I need to upgrade from 6.1.2 to 8.5.1. As there is no direct upgrade path from 6.1.2 to 8.5.1 so i will go to 6.1.4 1st & then to 8.5.1I would like to know the below:1. Is it mandatory to have CUWL license as soon as i upgrade to 8.5.1? Without th...
Hello,We currently use the 2821 to terminate an Internet SIP trunk and pass the traffic to an internal SIP server. As I don't need as robust of a router with a new deployment, I'm looking for the same functionality but with a less expensive option t...
So here is another interesting issue. I have a server group that I only use for testing. Currently I can login to the publisher's OS admin page just fine, but I can't login to the subscriber's OS admin page using the same account. I can login to the ...
Hi,Is there are way to auto disconnect a call from an FXO port after a period of time using Loopstart on a 2911 using 15.1.3 IOS?Have got a paging system on the other end of the FXO port - after dialing from an IP Phone....if the IP Phone dies not te...
Subject | Author | Posted |
02-06-2023 12:21 PM | ||
02-06-2023 10:54 AM | ||
02-06-2023 02:33 AM | ||
02-01-2023 09:39 PM | ||
01-25-2023 05:07 AM |
User | Count |
10 | |
5 | |
4 | |
4 | |
2 |
