IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6330 Views
  • 14 replies
Hi,We have an intermittent issue (1 out of 5 calls) where the greeting that has been recorded randomly drops out. The WAV file itself is faultless (I have downloaded it to my PC and there is not loss or dropout on the actual file) and as mentioned th...
My company will be moving into a new building and will have new phone numbers.  We want to forward our main # to a message stating "please note the number to XYZ has changed to xxx-xxx-xxxx", then once the message plays, transfer the call to the new ...
jafetters by Level 1
  • 650 Views
  • 5 replies
Hello everyone.           From last few days i am trying to get TAPS working..I have installed CUCm 7.x UCCX 7.x ..The integration is all done...Installed TAPS.exe on UCCX ...Script and trigger all working.. The phones are auto registered ..Now when ...
my customer is using 2801 as CME and 3560 POE switch. when customer changed the WAN link from that time customer is facing outbound calls issue, he can not make an outbound call. phone, switch, vg and cme are at same site.what could be the issueregar...
Hi,I have enabled SNMP in CUCM Server 8.5.1.12025-1. and I am using HP NNM (Network Node Manager) as NMS.In CUCM, i have specified the correct Community String and correct NMS IP Addr. The CUCM is being discovered in NNM but the registered phones sta...
