IP Telephony and Phones
Labels
Resolved! IDLE URL
Hi,If i configure IDLE URL in enterprise parameters of CUCM 7.x, and when later when user login into a phone using Extension mobility, will these IDLE URL will still be working or it will be over written. Device profile does not have IDLE URL paramet...
Ajay Singh by Beginner
  • 1274 Views
  • 4 replies
Hi,I have configured a SIP trunk in CCM. There are no problems with incoming calls but  I need to change SIP headers for outgoing calls. I need to send host name instead of IP address and I need to add "user=phone" in the header. ieINVITE sip:6303333...
Hello,I have a problem with the UCCX which displays error on the Backup page as per the attached:•    UCCX System version: 8.0.2.11003-10•    Installed on  Linux                     admin: show version active Active Master Version: 8.5.1.10000-26Acti...
I am starting to configure a 2921 with an ISM for voicemail.I've configured as follows, but telnet and ssh advises that the connection is refused:RTR#ssh 192.168.4.5% Connection refused by remote hostconfiguration that i have added:interface ISM0/0 i...
ashleyisa by Beginner
  • 1499 Views
  • 2 replies
