IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5736 Views
  • 14 replies
Hi,I have the following files on my router's flash. apps42.8-4-1-23.sbncnu42.8-4-1-23.sbncvm42sccp.8-4-1-23.sbndsp42.8-4-1-23.sbnjar42sccp.8-4-1-23.sbnSCCP42.8-4-2S.loadsterm42.default.loadsterm62.default.loadsand apps42.9-1-1TH1-16.sbncnu42.9-1-1TH1...
techguy by Level 4
  • 8155 Views
  • 8 replies
Hi, I'd like to enable 'Span to PC Port' on a cisco 7941 - [Settings - Device Configuration - Ethernet Configuration - Span to PC Port] so we can have a look at the traffic with an analyser and ensure the TOS value is correct.We are using v7.1.3 CUCM...
Hi,I am planning to setup a VoIP lab network using 2611XM and CME4.0(1). My 2611XM doesn't have enough flash memory. I was only able to load an IOS for CME 4.0(1). Now I cannot extract the cme tar file to 2611XM flash memory. Now, is this necessary t...
Hello All,  I have a customer that has some 7925 phones.  Every now and then they go to use the phone and the screen is black, like it is turned off.  The buttons are not responsive.  The only way to get it to come back on is to remove the battery.  ...
I'm trying to set the IP address of a gatekeeper on a 2811 router using IOS15.1 and IPv6. Specifcally the "RAS address". I have turned on the port 1719 for registration (server registration-port 1719) but the gatekeeper can't register anything becasu...
