IP Telephony and Phones
Labels
Hey all,I have a replacation issue in my bran spanking new cluster.  No users on it as of yet so it's a little upsetting.The history of this issue the pub had a hardrive issue.  Once fixed we had to reinstall.  Names and ip address stayed the same. T...
rbblue234 by Level 1
  • 8197 Views
  • 4 replies
Hi Guys, we gotta CUCM7.1(3) and Iexperience problem that if I set CFA CSS matching only onetranlation pattern, translation of Calling number definedin this TP doesnt work when signalizing call to outside GW.When I set this CSS for as line CSS and di...
Hi all,I have a 2851 CME router with 45 IP-Phones registering to it.Now we need to monitor (only logs) all incoming and out going calls from these extensions.Management wants to know who is dialing whom and the duration of the call.I understand that ...
Hey guys --in CUxAC, when a search is performed on the client, it only allows you to search one field at a time, so Last Name, or Number only for example, if I type in 'Smith' in the last name field, and 'John', in the first name field, it will remov...
ouhakheme by Level 3
  • 1041 Views
  • 2 replies
Hi all,Could you please share, in which all cases a transcoder resource is required ?I know only about the two instances as below.1) G729 call from CUCM to Unity connection, as Unity connection only supports G.7112) CUBE environment,I would appreciat...
Hi,I have successfully configured MVA. I do have H.323 gateways & the CUCM version is 7.1.5b...If i dial the MVA no i do get the ICR prompt & it asks me to put the PIN..It asks to put 1 for placing new calls...Till this point it's perfect...The probl...
We have a Call Manager 4.2 installation which has requested, they'd like to position a handset at the front door. The phone is only to dial directly to the Operator at the front desk.I've set the Calling Search Space partition to "OnSite". But that d...
