IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 1179 Views
  • 6 replies
I have a group of numbers 33379XX.  I need to send these calls to a PBX via a gateway.  If for any reason they cannot go to the gateway, they need to go to IP phones with identical extensions.  So if 3337901 doesn't make it through to the GW, I want ...
Hi,my problem is that a user has „single beep“ (like a Keybutton pressing) during the call, but only one side hears this "beep"I checked the Callmanager Tace Files and I find at every calls the following states. 02/07/2011 16:25:41.067 CCM|StationD: ...
I'm looking for an advanced ip services bundle that includes SRST 4.1 or higher. The Cisco Feature Navigator seems to cut off at SRST 4.0 for some reason. I'm currently running c2800nm-advipservicesk9-mz.124-25c which apparently only has SRST 4.0 and...
