IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5907 Views
  • 14 replies
Is there  way in UCCX to follow the flow of a call in to and out of different queues? Would I use the CDRs from Call Manager or is there a better way to look at the calls within UCCX?Any help would be greatly appreciated. Thanks, Michael Putney
putney_m by Level 1
  • 456 Views
  • 1 replies
Hi Gurus,Is there a maximum number of Translation rules that can be configured on CUCM i.e. a design or a suggested/tested limit?I have tried drilling through various documents and have found other limits like CTI RP's etc but none yet for Translatio...
VoipRocks by Level 1
  • 3745 Views
  • 5 replies
Hey,Prevoisly i've managed to get Nokia phones running on SIP (and SCCP) but i'm struggling to get my Android phone registered using SipDroid client. Has anyone managed to get their Android phone registered to the call manager using any 3rd part Andr...
eoinwhite by Level 1
  • 16633 Views
  • 25 replies
Hi,I want to download some log files from CUCM to my local SFTP server. I used the command "file get", but i got a problem "Invalid download directory specified ". The directory was created local, but there was no files. Someone has one solution for ...
Hi to all,any one of you know if it is possible to set a button or softkey to make the combination of callforwardall+phone number?I will explain better...i want users press a button to forward all call to 656(fixed number) and not he presses call for...
Dear Netpro gurus,One of my customers has "tail-end hop off" setup on their CUCM cluster.  To recognize different offices, the client has the following site codes:-*02 - Hong Kong*04 - Beijing*06 - ShanghaiSo when we want to dial Beijing PSTN mobile ...
huntlee by Level 1
  • 355 Views
  • 3 replies
I am trying to upgrade a customer from 6.1.3.1000 to 6.1.5.12900. I first attempted this by downloading the update and burrning it to a DVD. I started the update and it hung about 15 minutes into the update at the following lineupgrade_manager.sh|Cop...
donmitswv by Level 1
  • 568 Views
  • 1 replies
