IP Telephony and Phones
Labels
Hello!i have a problem with sending fax through a cisco ata 186 adapter, i can send to some numbers.. but thats not many.i have a ata 186-l2-A adapter with Version: v3.1.0 atasccp connected to a cisco callmanager express router with cme 4.1i have att...
Hi,I found an error when i try to configured SRST single-line DN as belowVIPTVGW07(config)#call-manager-fallback VIPTVGW07(config-cm-fallback)#max-dn ?   <1-960>  Maximum single/dual/octo line  directory numbers supported VIPTVGW07(config-cm-fallb...
Rojer-bkk by Level 1
  • 963 Views
  • 6 replies
I have a 7911 that I was trying to upgrade the firmware on and I read it needed older firmware to step to the newest. I tried to do a factory reset (Hold #, Plug in, Release # after message light flashes, 123456789*0#) unti now is a blank screen, pul...
nshoe18 by Level 1
  • 462 Views
  • 1 replies
I am trying to make a Application User that only has the ability to add/change phones, add/change Directory Numbers, associate Directory Numbers with phones and view the Route Plan Report.  I created a role (User Management/Role) and checked the boxe...
mmedwid by Level 3
  • 376 Views
  • 1 replies
HiDoes anyone know wether you can get any detailed information from the Call Manager from a monitoring perspective?We manage a lot of Call Managers but are only able to do Ping and Poll at present with the CUCM. We want to be able to check the status...
