We are currently running CUCM 7.0.1.I have a phone A (12345) that is setup to forward to phone B (12340) here are the settings:Phone ACall Forarward Settings Voice Mail DestinationForward Busy Internal ...
Hi,I want to user the Recording function on Cisco UCM8. This requires an additional server called the recorder accessed via a SIP trunk.What are some good software-based products that are used for the Recoder that can be used with Cisco UCM (commeri...
Hello,I'm looking for an FXS to FXO converter, to be connected to an FXS port of a Cisco router.Do you know a reliable (and possibily cheap) one?Thanks and regards.
Hi All, I am using CUCM 6.1, I configured MeetMe conference with one number. In softkey template, there is confList and RmList softkey. when I initiate meetme conference then participants join to conference, I can not use confList and RmList softkey ...
Hello,Just wondering if anyone has used a tool that can be used to help create documentation on a UC installation. I have used the Uplinx software and it does an amazing job but my organization focuses on smaller installations featuring the CUCMBE so...
I have programmed and saved both the user name and telephone number but the system erases the telephone number as the phone seems to reboot on a daily basis. I have heard that this is a bug in the system as it has no power source to remember the sto...
Does anyone have an idea why a user that placed their personal communicator in "away" statusnow can't come out of "away" status and into "available" status? Nothing has changed that I know of, and all other users are functioning properly.
HiDoes anyone know any 3rd party handset for Cisco 7945G ?Look forward on your reply
CallManager 8.0(3a) I disabled the DNS Client during install, I want to add some SIP Trunks (CVP) that use DNS SRV, can I edit the hosts file to add my CVP servers?Or do I need to turn the DNS client back on (can’t recall what the CLI entry), add the...
Hi,I have a configuration with CM 7.1 and AD integration.What will happen if I remove the LDAP integration?Will the users become normal endusers?Or will they be deleted?Just wondering.Thanks,Jan
Anybody out there have 6941 phones deployed with call recording enabled? According to the compatibility matrix, the phones are supposed to support Call Manger based BIB recording:http://developer.cisco.com/web/sip/wikidocs;jsessionid=F75FD6FBFC21918...
Hi, we are planning to move some phones and users from one CUCM 7.1 cluster to another CUCM 7.1 cluster. Are there ways I can export the selected phone info and user's info, then import into another cluster? Can we export the user's personal director...
Hello all,I've an issue using a 3845 router as a voice gateway.Internal voip calls are placed through a call manager 6 and external calls go through an E1 PRI interface.Users claim that after ten seconds of two-way audio conversation the call is auto...
Dear Support Community,We are planning to upgrade our CUCM from version 6.14 to version 8.0X or 8.X. Which version would you recommend and why? Stability is our main concern.Thanks.
Background: We run CUCM 6.1.2 and use VoPSTN for all remote sites. The bandwidth for all locations has been set to 1 kbps to force all calls from remote sites through PSTN (AAR).I have a hunt pilot for a support team that users dial to reach the team...
Subject | Author | Posted |
03-19-2025 06:53 AM | ||
03-19-2025 05:15 AM | ||
03-18-2025 05:41 AM | ||
03-16-2025 03:42 AM | ||
03-14-2025 01:29 AM |
User | Count |
6 | |
3 | |
3 | |
1 | |
1 |
