IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6331 Views
  • 14 replies
Hi,I have a CUCM cluster in Germany running 6.1.2.1000-13, the local installed is 6.1.1.2000-1 (german)Have set the default Enterprise parameters to German and the device pool shows German for the network locale.I have an issue though that the user a...
bigcappa1 by Level 4
  • 1470 Views
  • 2 replies
Site ADial-peer voice 10 voipDestination-pattern 9.TSession target ipv4:10.1.1.1 Site BDial-peer voice 100 potsDestination pattern .TPort 2/0:15Scenario:-----------A user in Site A places a call to pstn . This call goes to pstn through Site B. Now ...
SJ SJ by Level 1
  • 894 Views
  • 7 replies
Hi All,I am in the initial phase of setting up a 1751V with 2 port FXO and 2 port FXS card to use with Cisco CME. Router has got 32M Flash and 256K PVDM. Please find the attached output of "show version" and "show INV" for your analysis.The issues is...
hi guys,we have 22 floor five star hotel in each room i have three phones with same extension and i need to create one user for three of phones with same entension. so that i will have same voice mail.what i need to upload BAT file this scenario.my q...
I wonder if anyone can help. I have a non gatekeeper trunk between CUCM 8.0 and Callmanager 3.3 If we try to do an ad hoc conference  with 2 parties on one site and the 3rd on the other. The call fails to the 3rd party.I have tried setting up MTP on ...
pcromwell by Level 3
  • 371 Views
  • 2 replies
If I use a UCS C200 server with Emergency Responder 8.5(1) am I required to run ESXi or can I install Emergency Responder directly on the hardware without ESXi? Table 8 Supported UCS Platformshttp://www.cisco.com/en/US/products/sw/voicesw/ps842/prod...
I have an ASA 5505 that I'm trying ti use to get a Phone Proxy running.  At the moment, the phone is plugged into a switch that is then plugged into the outside interface on the ASA.  I've tried a couple of different configurations that I saw in a co...
refram by Level 3
  • 581 Views
  • 2 replies
Referring to the topology in the attached diagramI would like to know how it is possible to send a fax from Site B (Branch) using the PSTN line of Site A (Head Office) over the WANWhat are the commands and configurationI can make phone calls over the...
nascoentr by Level 1
  • 1558 Views
  • 5 replies
