IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6721 Views
  • 14 replies
I am looking at deploying 2X 3925 with CUBE. the SIP provider is delivering calls as g.729, most of the network uses this but some areas including the contact centre use g.711. where do I need to transcode these calls? is it on the CUBE gateways and ...
bowmail by Level 1
  • 687 Views
  • 2 replies
Hi ;i just implemented and deploy about 1000 units ip phone for one of the customer. All ip phone been configured with DN, PT, CSS and etc, and register to CUCM 7.1.3 work well. But i found in IP Phone config i miss configure one parameter "Owner Use...
potan by Level 1
  • 3480 Views
  • 4 replies
Resolved! Cisco phone parts
We having been having many handset switches fail recently.  Does any one know of a place to get replacement switches?  I have been using ones from phones that are dead from other issues, but I would like to find a supply.  Thanks.
jowagner by Level 1
  • 3830 Views
  • 2 replies
Hi,We have a CUCM 7.1.5 cluster with 1 publisher and two subscribers.We had assigned IPs from same segment initially to this cluster.Then we have done below changes:Changed the IP of Subscriber 1 (new subnet)Changed the IP and hostname of Subscriber ...
lalit by Level 1
  • 1171 Views
  • 5 replies
Resolved! CDR records
Does anyone know if the CDR records are any different  from callmanager 4.1 and version 8.0.The reason for asking is that we have a reporting package for version 4.1
pcromwell by Level 3
  • 531 Views
  • 2 replies
Hi,I have a CUCM cluster in Germany running 6.1.2.1000-13, the local installed is 6.1.1.2000-1 (german)Have set the default Enterprise parameters to German and the device pool shows German for the network locale.I have an issue though that the user a...
bigcappa1 by Level 4
  • 1483 Views
  • 2 replies
