IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6326 Views
  • 14 replies
HiWe have recently purchased a UC520 device with a number of 7962 IP Phones.The issue is, when we plug the phone into the LAN, in the Cisco Configuration Assistant, the device correctly registers as a 7962. Once I modify the details, and try and appl...
hi ;I fed up troubleshooting the caller ID please I need some help;I have cisco router 2821 , FXO ports , Call mnager express installed IP telephones 7940, the caller ID service already enabled from the telco company..I already configured the caller ...
hz1777999 by Level 1
  • 1064 Views
  • 5 replies
Hi,Please help me on this, my Cisco IP phone ( model 7962 ) is not booting, it is getting power, but no luck after that, it flashes the cisco logo and MAC address and then boots again, download of firmware is also not happening.If it boots, I can go ...
OK, I think this will work, but don't have the paging horns to test my theory.Scenario:  I have a customer that has overhead paging setup across Valcom horns via a V-9970 paging controller connected to an FXS port (x9100).  They also have ephone-dn i...
Kynnzak by Level 1
  • 409 Views
  • 1 replies
Hi, I have CUCM 7.1.3.30000-1 and recently the company bought some IP Phones 6911, bue I cannot add them to the telephony network. I've read that version of CUCM 8.0 (+) have support for that. ¿Does Cisco has a patch upgrade or a support pack?I would...
