IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6325 Views
  • 14 replies
We are running CUCMBE 7.1.3 and have multiple buildings. One PSTN connection so we are implementing a 3rd party E911 solution. The problem is that we have a handful of DNs that are in different bldgs using the same dn/partition. They require this DN ...
johnnywan by Level 1
  • 281 Views
  • 1 replies
Hi,I think I already know the answer is no! But can anyone tell me for definite whether call manager will collect CDR information about a call coming in from the PSTN, through a h.323 controlled voice gateway, to an extension in call manager, when th...
Hi all,I've got the audio source file uploaded and ready to go. I would like to find out where would be the best place to apply the MOH audio source to all devices. I am looking at the "Common Device Configuration" page. Would that be the best place ...
dtran by Level 6
  • 759 Views
  • 3 replies
I know that the period (.), represents any digit. Recently i came over a config wherethe dial-peer looked like this:dial-peer voice 100 voip huntstop preference 1 destination-pattern .. session protocol sipv2...The destination-pattern is defined by t...
ov by Level 1
  • 700 Views
  • 2 replies
Hi,We have CUCM 8.0, IP phone 7975, FXO cardI have 2 FXO ports through which user is doing PSTN calling.We want to monitor the FXO card. If one FXO port is busy, it should indicate on phone line so that user can monitor and can directly use second li...
Hello,Today we discovered that a number of calls are being made from our site to global destinations.  We checked the call manager and the logs are not showing any abuse internally so now our attention is on the router ISDN.  We haven't any access li...
