IP Telephony and Phones
Labels
dear all,I have a requirement as mentioned belowif an end user calls from outside  or inside company extesion number the ip phone is ringing  if there is no one to pick the call the same call should be trnasfered to my mobile number is it possible to...
CUCM ver 7.1.3  cisco 7936 ver 3.3.20.  We are trying to use the meet me button on the 7936 but it does not work.  Meet me confr./button works fine on other phone types 7970,7945.  We go off hook---menu button---sellect call function---select meet me...
rsadelski by Level 1
  • 2208 Views
  • 4 replies
Hi all,I am encountering a problem with replication between these two servers.All servers do not have a replication count of 348.All servers have a good replication status.View DetailsServerNumber of Replicates CreatedReplicate_State10.182.9.22702 - ...
smsangola by Level 1
  • 3924 Views
  • 11 replies
Hi,I am planning to install and configure Cisco CTL client and two tokens are required as a pre-requisite. I need to know whether these token has to be purchased from Cisco and if there is a prt number for these tokens,or the Communications Manager i...
