IP Telephony and Phones
Labels
Hi groupI'm trying to configure unity express on a 2801 so unified call manager can use it for voice mail, I have set up my CTI Route points and ports on Unified Call Manager but I have hit a snag on the 2801 with the licence.If I do a 'show software...
martynch1 by Level 1
  • 2286 Views
  • 8 replies
Conference call softkey is not able to function for Cisco IP Conference station 7936I had made the first phone call and try to make conference call by press the arrow button under the Confrn and the phone has no response. I think this problem is not ...
Hi,I have configured a Tandberg E20 on CM 6.1.3.The  tandberg registers and all IP phones can call tandberg E20, but the tandberg can call nothing.The partitions and calling search spaces are OK. The same SIP config works for a X-lite softphone.Any h...
Hi,Would like to know if an ip phone faulty can caused a switch down ?Have experienced the following,Suspect a port caused high CPU in the switch and then caused the UDLD to shutdown the trunk links.I am able to trace that the port is used by an cisc...
Hi all,        My client requirement is:They have got three PSTN numbers. I have connected these to three FXO ports on UC540. For After Office hours they want the calls transfered to a mobile number. Which they should be able to change on weekly basi...
Hi,We have an IPCC Express server running ver 7.01 and Agent Desktops running ver 6 on XP Machines.We are now rolling out win7 PC's and need to run the agent desktop software on them.We downloaded the new 7.62 ver but had a dll issue on win7. This wa...
This bundle P/N states it includes 50 seats. But I still think you need the DLUs for the actual phones. So what does that 50 seat limit actualy mean? is there some kind of seat license that prevents you adding more than 50 users (i.e.nothing to do wi...
billybjo1 by Level 3
  • 564 Views
  • 5 replies
Hi,I am trying to configure UC540 with Cisco 508G and SIP phones from Syspine IP 310 and a softphone from 3CX.Extensions are:Cisco 508G = 203Syspine IP 310 = 6033CX SIP soft phone = 604All phones are in common Vlan and same network space.Exten 603 an...
We have a remote location with 30 users and a 100Mb Internet connection (I know. Crazy).  They will be moving to our location in 4 months. We have a 50/50Mb MetroEnet Internet connection and a ASA 5510 with CallMan 7.1.3We have extra phones for them....
Hello,We are looking for a recording solution compatible with Cisco Unified Communications Manager 8.0 in Spain.The required features are the following:• Fault Tolerance: We need kind of redundancy. Normal practice would be a server in the central cu...
We need a way to confirm that all phoens took the new load when we upgrade a load.  How can we do this with an SNMP walk ?WIll this table show the phone load verison that is currently on each phone ?I have heard of using this :snmpwalk on ccmPhoneSta...
markhayek by Level 1
  • 503 Views
  • 2 replies
