IP Telephony and Phones
Labels
help requiredi have setup a small home network to practice voip, the lab consists ofone 3550 switch a cisco 2621xm router with a aim-cue voicemail module installed and running ios c2600-ipvoicek9-mz.124-11.XJ4.bin a cisco 2621 acting as a ntp server ...
Since upgrading to CER 7.1.1.20000-1 it is no longer identifying phones after running switch-port/phone update. I see all my switches and ports are in the correct ERL. SNMP strings are correct for Call Manager and CER, i can ping Call Manager from CE...
jszapipes by Level 1
  • 3208 Views
  • 6 replies
Hi All,I would like to ask if somebody how is the best solution to monitor a SIP Trunk?Because we are having now a SME Cluster and to this cluster we will connect a CUCM Cluster but currently I have no idea how to monitor it.Is it possible that the C...
7945 SIP45.9-0-3S--------CallManager 8.0(3a)----SIP Trunk----3845/IOS 151-2.T1-------PRI/PSTN The below URL states Call Preservation is on by default on SIP Trunks in CallManager. However in testing SIP SRST I found my call to PSTN dropped when CallM...
