IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5540 Views
  • 14 replies
Hi,does anyone know if BAT can be configured to change the CSS for the forward settings of hunt pilot. I've done it for exts but there doesn't appear to be away for hunt pilots to be changed.I need this because since our upgrade to v7 call forwards h...
hi,VIC3-2FXS/DID which is update version of VIC2-2FXS is not function well although configuration is same as vic2-2fxs, I can able to dial and there is ring but after picking by receiver within seconds line get disconnected I can hardly hear hello**!...
Hi, Seems as though I'm having a ghard drive failureon one of my servers. Trouble is that I'm not sure I'm can identify the correct drive- 2 in system. Can you point to drive in bay 0 or 1 please?Oct 22 04:17:58, , Warning,  kernel, : mptbase: ioc0: ...
Dear AllI want to deploy Cisco Gatekeeper in my Company's IPTelephony infrastructure as we have more that 60 small IPT clusters at present. I am planning to use 3825 or 3845 ISR. Please let me know how many zones can be configured in a gateleeper. I ...
I've seen lots of documentation on how to use multi level access and roles within unified communications manager. It's everywhere.  What isn't 'everywhere' is a breakdown of what each checkbox in the role 'really gives you'.  Some are worded better t...
jkittle99 by Level 4
  • 678 Views
  • 1 replies
My customer has a Hoot n Holler application on their entreprise that consists of 7936s plugged into fxs ports which PLAR to a VoIP dial-peer with "session protocol multicast" and that, of course, gets multicast around the enterprise.So my challenge i...
mmertens by Level 1
  • 1222 Views
  • 6 replies
Hi Guys,I am trying to test a Hunt Pilot configuration because my Customer have the following need:I did the following setup in laboratory:Directory Number 71000, 72000, 73000, 74000Pilot: 75000broadcastI used the DN 71000 and did the following test:...
Hello,I was doing some scripting for an AA and i wanted to route the calls based on the DNIS, however on the CUE script editor I couldn't actually debug the script and since my script wasn't properly workingi enabled some debugging on the CUE and rea...
Hi all,Has anyone done any type of integration between Lotus Sametime and CUCM/CUC ? I've got a Cisco IPTel environment running CUCM 7.1.3b SU2, Unity Connection 8.0.2 and a Lotus Sametime environment running version 8.5.2. I am looking into to see i...
dtran by Level 6
  • 1609 Views
  • 3 replies
