hi guys When I get a call on my extension.Appears the number of the person who is calling. Example: 089123456 (appears well on my IP Phone).I want appears the name of the person who is calling me.Example comes from one dialout number 089123456, I...
Is there anyway to go back in the CDR logs and find out what the original calling party number was before it hits a translation pattern? I'm trying to trace a call, but it is translated immediatly. Thanks!
Hello,I have an e1 and i need to configure whith this way:1-15 time slot inbound17-31 time slot outboundi dont know how to be diferenciated beetween in and outHow many dial peer in its necesary? My e1 give me 2 digits. In level 2 is up.Im using this ...
Is there way to change the settings on a 7965, so that you need to press a line key in order toanswer a call? not by just lifting the handset.
Hello people,I have some 800 7921 phones I need to setup (seppret from default over the net), I have found out that I can make a config file and put on TFTP server.How do batch upload to the internal TFTP server when running 7.1 version. I dont want ...
Hi,I am facing issue with the call forwarding . Calls forwarded to national PSTN or mobile numbers disconnect after 10-15 seconds if unanswered by the destination. Can anybody know if there is any timer configuration in call manager , where we can se...
Hello All,We have Cisco 1861, I have done Voip deployment on it, i attached my running-configuration & Flash details, can anyone look it, help me or please let me know if I am wrong anywhere in config because I'm Unable to open Cisco Unified Communi...
Hi,I try to understand the CCA process and the CLI result when an auto-attendant is configured.On the CUE card, I dont' find mapping for option part (script parameters), only prompt management.For example, option 0=> extension 202, option 1=> extens...
Hey everyone,We just got a major problem happen to us. We recently upgraded the hardware of our Publisher and Subscriber from 7825 to 7835s. We had e-mailed Cisco to send us a new license with an updated MAC address of the new server. We uploaded the...
help requiredi have setup a small home network to practice voip, the lab consists ofone 3550 switch a cisco 2621xm router with a aim-cue voicemail module installed and running ios c2600-ipvoicek9-mz.124-11.XJ4.bin a cisco 2621 acting as a ntp server ...
I have SPA508, 504 and 525 phones running SIP and when they receive the Bye, the phones don't hang up. I have heard this is by design, but just can't see why. Is there anyone out here who knows how to get the phone to hang up when it receives a Bye?
So I'm trying to configure some translation rules as spelled out in this article:http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtmlHowever my hardware is an older 3640 which only has enough memory to r...
Trying to avoid accidental 911 calls. Sending 911 calls to a call handler then to the CER and out to 911. Everything works except the CER shows Unity as the caller, ELIN is correct.Test setup, not live yet:Test number is CTI-route point,3299, which ...
CUCM 8.0.2.40000-1Unity 7.1.3Gateway 2811 MGCP-FXOIts Very critical Experts...Help me out...Thank you.Incoming call xxx-xxx-xxxx ----->Autoattendent--->punch down the ext--->Phone rigns(caller Id as 'O')Look at traces.... /* Style Definitions */ t...
Hi,I have a working setup with a centralized IOS gatekeeper providing inter-zone CAC for voice calls between CUCM and several CMEs.I now want to add video calls (experimenting with Video Adavantage).My initial goal is to add 1x 384k video call to the...
| Subject | Author | Posted |
| 11-17-2025 06:09 AM | ||
| 10-17-2025 09:01 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM | ||
| 09-24-2025 11:48 AM |
| User | Count |
| 4 | |
| 2 | |
| 1 | |
| 1 | |
| 1 |
