IP Telephony and Phones
Labels
Hello,I need some help to sort out an issue concerning the integration of CUE 8.0 with CUCM 8.0. I have configured the CTI ports and CTI route point in CUCM and all of them are registered.When I issue the command "show ccn status ccm-manager" in CUE,...
cg100668 by Level 1
  • 364 Views
  • 1 replies
In several Cisco documents i have seeing that reverse (PTR) records should be update when CUCM name is change.Somebody knows the reason of this?. Up to my knowledge CUCM only uses DNS forward A record at boot up for filling the hosts, rhosts, sqlhost...
aalejo by Level 5
  • 2433 Views
  • 4 replies
Hi all,We're using a CUCM 6.1.4 and now trying to setup a call recording.I use a SIP Trunk to signalize to the recording server. The phones of third generation have Built-In-Bridge enabled, Recording Profile on the Line ist defined an enabled too. Th...
Is there a document that tells what the fields are in the OutputCmrRecord line of the CallManager trace file?Here is an example:outputCmrData CMR data - 2,3,232851,3,"3313",59770361,1271856744,1103,35296,1097,35104,0,0,0,"ace5e2e2-943e-44a4-8235-818d...
Resolved! Viewmail 8.0.3
ENVIRONMENT:Unity 5.0.1Windows 7 Enterprise 32-bitExchange 2007MS Outlook 2007We recently upgraded our Viewmail client on some test workstations from 7.0.2 to 8.0.3 and noticed a significant delay in playback. Also, the progress bar is not synchonize...
dcagampan by Level 1
  • 733 Views
  • 3 replies
Dear All,I have a fax machine model ( Muratec F 68P) which is terminated on Cisco VG224 , the VG224 is using SCCP  with CUCM 7.1.3 ,the problem is when I need to send a fax from the fax machine I can't send and when I used the fax for a voice call it...
Hi Guys,My Customer have a one CallManager version 4.2.3 and will be migrate to 7.1 using the another machine. I Not know nothing about the DMA and I have the following questions:- When I will be configure the new machine the name have that be the sa...
Will a Cisco UC 500 voice system work with a poe switch from another manufacturer?  Customer has poe switch already installed and doesn't want to purchase another switch unless a necessity to get full-featured use of the Cisco voice system.  Which Ci...
I had an issue with 6921 phones not staying in the correct VLAN.Here's the sample config:interface f0/1switch access vlan 50sw voice vlan 900sw mode accessThe configuration initially worked.  I was resetting and rebooting the phones and switches seve...
francisg by Level 1
  • 852 Views
  • 1 replies
