HelloI have trouble configuring the CME / CUE because the LED display, voice mail does not work properly when the user receives messages (the lamp does not light)Here I leave the sh run of the CME / CUE.Thank you for your help.
I have a standard vg204 box runing sccp. i have connected at analog phone to port 0/0 and configured that port in cucm. Analog phone op port 0/0 number 222 is to call IP phone 952 when picked up. It works as expected.BUT when i hang up on my IP phone...
Hello All,I am fairly new with CUCM and need some advice as to how I can efficiently provide my users with the solution they need.I have extension 7080. Depending on the time of day, I need that extension to forward to one of three extensions.Betwee...
Is there a way to change the forwarding of a number when not on a phone attached to the Cisco UCM cluster? For example let's say currently DID 650-555-1234 which goes to UCM forwards to my cell phone at 650-444-5678, Now my shift is over and I want...
Hi All,Am experiencing a problem with my telephony network consisting of satellites site with CCME and a central site with CCM 4.1. Intra sites calls go fine, but inter-sites calls ring, get connected when picked up but no voice can be heard.This is ...
I was wondering if anyone could solve my problem. Im currently trying to set a group of 9 Cisco ip phones 7940 to an network to where they will be able to call within the group but have no outside lines. The phones in question are all several miles a...
Hello,I have a Cisco 2811 gateway with a E1 card installed (used with CUCM 6.1), I set up voice translation rules so that i can have direct lines. The problem i have is that when i call from landline phone it works great the line is redirected to th...
Hello All,I have only one question about CF card,1: CF card means flash of router or any expandable card ?Thanks
Hello,i'm testing bladeware vs. cisco gw. If i try fax trough t.37 all is fine. But if i send fax through t.38, i have trouble with ports. First is opened RTP stream and then is negotiated fax transmition with t38. All is fine, but my gw chose new po...
We have several 3845 voice gateways at our various locations. Many of these have several different PRI connections and most are running H.323 protocol. I have been looking at the CDR Analysis and Reporting area in CUCM Serviceability and specifical...
Hi All,I have a Linksys WRT54G connected to the Internet and the following ports are enabled:5060-5061 SIP16384-16483 RIPThen there is a Linksys SPA2102 connected to the WRT54G. The SPA2102 routes to the Internet (e.g. there is a computer connected ...
Hi guys,we have a issue with standard local route groups.Is it possibile, that QSIG-features, like calling name presentation, don't work with standard local route groups?If i associated a routepattern directly with a Route-Group (the same as the conf...
Hi,I have the design belowPSTN Provider <--SIP Trunk--> CUBE <--SIP Trunl--> CUCM8Ringback tone for external callers is UK Tone. But we are in France. So we'd like French tone (like cptone FR on an E1 voice port)Is it possible to modify that with the...
Hi guys,i have a unity 8.0, a cucm 8.0 and an 2921 H.323 VG with one E1 PRI to PSTN.We configured a notification device to the user on the unity. The notification call onnet works well, but offnet it doesn't work!I see in the sdi debugs a match, and ...
Hi,we are trying to connect a CUCM (Ver. 7.1(3b)SU2) with MGCP over a E1 trunk to a Hipath 4000. We use for the QSIG ECMA with Globale Values.Features like callback and call forward by reroute works fine, but we don't get the caller name on the Cisco...
| Subject | Author | Posted |
| 12-10-2025 11:24 AM | ||
| 12-10-2025 05:17 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM |
| User | Count |
| 4 | |
| 2 | |
| 2 | |
| 1 | |
| 1 |
